This is a page filled with the letter "H" and printed. you can see the result of the printer. the white black lines, both horizontal and vertical.
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
