I recommend restoring the old non-hacked firmware. To do this, you will need to put it in Recovery Mode, and then iTunes will ask to restore it.
Instructions:
1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
2. Disconnect the USB cable from the iPhone or iPod touch.
3. Power off the device (Press and hold the Sleep/Wake button for a few
seconds until the red slider appears, then slide the slider. Wait for
the the iPhone or iPod touch to turn off.
4. Press and hold the Home button while reconnecting USB cable. When you reconnect USB, the device should then power on.
*Note: If you see the message "Charging... Please Wait" or you see the screen
pictured below, let the device charge for at least 10 minutes to ensure
the battery has some charge and then start with step 2 again.
5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
6.When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message.
*If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
7. Click OK, and restore device.
Apple Support Article Best Regards,
Sam
Was this information helpful? Please rate it!
