Question about LG 37LG30 37 in. LCD HDTV
LG 37LY95 after about 35 minutes the screen gets discolouration
  • LG Master
  • 8,457 Answers
The tv board that call the T-CON board it is dying that why the tv LCD screen panel gets discoloration after tv on for awhile.This T-CON board only job are to decoded pictures pixels before it go onto the tv LCD screen panel.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-CON board for the replacement.
Posted on Jul 08, 2011
  • 11,361 Answers
That is more likly to be bad T-CON board, you can learn more about the failure mode of the T-CON board here:
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
LCD panel: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
You can try cooling it with electronics freeze spray used for troubleshooting to see if the problem will go away.
Please read my guides also:
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
6ya staff
SOURCE:
The tv had a bright flash then turned off. now picture is grainy and discoloured
Not likely to be a do it yourself repair so best advice would be have a shop look at it--power supply or main board are most likely.
Jun 14, 2012 | LG Televison & Video
Horizontall lines appear on the screen on booting screen gets discoloured for a short while
RUN the LCD BIST test D+Power button at boot, see if you get 4 solid colored screens
If you do then the video processor is failing. This means replacing the motherboard.
If issue occurs during the BIST, then the LCD is failing and LCD will need replacement.
Jun 25, 2010 | Dell XPS M1530 Laptop
Canon A95. Image on screen flashes and is discoloured. Photo same
It sounds bad ccd image chip in your Canon A95 camera and ccd imager chip will be replaced to get correct live view in camera mode.
Canon offers free of cost repair for said problem, click Canon CCD Imager Advisory for details.
Thanks.
Dec 26, 2009 | Canon PowerShot A95 Digital Camera
Cleaning the screen
Try hot soapy water, since a flat screen TV should be glass.
Feb 11, 2009 | Televison & Video
Green Screen - LG 42PX5D
hello, seems to be panel trouble, plasma and lcd main panels are not fixable, the color green isnt a good sign or it is a symptom of the panel being bad,
i know its a bad diagnosis but this is true with this color on a panel.
if it is a worth while set and you want to restore it theres few options one is replacement trough your waranty
the another is having the screen replaced by a service center this is to costly and rarely done by them they would advise you to get another set. at a retail price a screen replacement is as much or even more than the tv itself.
finally you may search online listings for a servicable tv same model and exchange the parts .
the third option is the best if your waranty is expired.
good luck hope this helps
happy holidays.
Dec 27, 2008 | LG 42PX5D 42 in. Plasma HDTV
Screen
Two possibilities can cause the issue .
1. A lose hinge assembly
2. A faulty LCD cable.or the LCD lamp
Try following the instructions given in the following wizard
http://tinyurl.com/6ojva6
In case your system is out of warranty and you need help opening parts , refer to the following
http://tinyurl.com/5w9nsv
Apr 09, 2008 | Computers & Internet
CANON PIXMA MP 460: PRINTING PHOTO- COLOUR PROBLEM.
change the print cartridge for color if yhat doesn't fix it get a new print head. Bob
Mar 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Tv discolouration
It sounds like your problem is magnetisation of the crt. Try to switch it on and off for 3 times: on for 1 minute, off for 3minutes, on for 2minutes and off for 5minutes. Then switch on and see if the discolouration dissappeares. IF not, then a technician needs to check the internal degauss circuits.
Jan 24, 2008 | Beko 324250WN 28" TV
Screen discolour
sounds like a burn spot on one of the tubes open up to get access to the tubes and cover each one individually to determine which one and replace
Dec 10, 2006 | Panasonic TX-42PT10 42" TV
CRT discoloured
If it's a deguass problem, you can glue some very small magnets to the sides of the crt tube itself, it could be the shadow mask, inside the monitor, and if it is then nothing will fix it, if you can get a deguass coil from somewhere that would tell the story real quickly
Nov 04, 2006 | LaCie Electron 22blue II 22" CRT Monitor
LG 37LG30 37 in. LCD HDTV Logo
681 people viewed this question
Ekse
RONALD CARTER JR
