Question about Panasonic Cameras
Do you know where i can get the step up ring for the panasonic hdc-sd90 for it to connect to the clt-1 3d lens, i think its 41.5mm to 46mm.i have got the camera & the 3d lens but have somehow lost the coupling ring and can't use the 3d lens on the camera without it. please try and help, thanks in advance,regards eric
6ya staff
SOURCE:
Anonymous
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Posted on Jan 03, 2008
Anonymous
SOURCE: Camera showing battery exhausted with new batteries
There are three battery type settings in the set up menu: Alkaline, COOLPiX(NiMH) and Lithium. Might be worth looking at. To be continued.
Posted on Feb 09, 2008
Anonymous
SOURCE: Drivers for Hitachi HDC-656E digital camera
fack you
Posted on Oct 22, 2008
Anonymous
SOURCE: nikon d90 lens plastic mount broke
UScamera is temporarily out of stock
Posted on Sep 01, 2009
Ty Price
  • 11967 Answers
SOURCE: My panasonic lumix dmc-zs6 has
Try here: http://www.precisioncamera.com/panasonic-camera-repair.html
Posted on Jun 20, 2011
Tip
Upload/Share Videos to SmugMug-Convert Panasonic SD90 AVCHD MTS files to 1080p...
Compress/Shrink SD90 AVCHD MTS to MOV for SmugMug with Keep Highest Quality <br /><br />I have a Panasonic Camcorder, HDC- SD90, which produces .mts files with 1920*1080 28Mbps. I record some more mts videos by sd90 and want to upload to SmugMug for sharing with my friends. SmugMug does a great job with MTS video, it supports 1080p HD and can take an MTS file directly. The upload times for an MTS file shot in 1080p (28Mbps!) though are too long, so I need to compress 1080/28Mbps video before uploading .To solve the problems, I recommend a professional program named <b>Final Mate</b>. This professional Camcorder Software - Final Mate can <b><a href="http://panasonic-avchd-converter.com/2011/06/upload-panasonic-sd90-recording-avchd-mts-video-to-smugmug-shrink-avchd-footages-to-mov/">Convert/Shrink Panasonic AVCHD footages to MOV for Upload/Share Videos to SmugMug</a></b> with best quality. <br /><br />Below is the fast guide for you to <b>Convert and Compress AVCHD files from Panasonic HDC-SD90 Camcorder to .MOV Videos with Highest Quality for Uploading/Sharing to SmugMug</b> on Windows XP, Windows Vista and Windows 7. <br /><br />Step 1. Get <b>Panasonic HDC-SD90 1080/28Mbps AVCHD footage to Final Mate</b>. <br />If you have already backup all your mts video recordings from Panasonic SD90 to your computer, you can browse your video path via "Add" and the software will automatically show your AVCHD clips in Resource Tab. <br /><br />Step 2. <b>Create a Movie for Convert Panasonic SD90 MTS Files</b>. <br />For conveting Panasoni HDC-SD90 MTS files to mov and keep highest quality for uploading on SmugMug. First need to create a movie for conversion by selecting Add &gt; For Conversion in Movies Tab for putting mts video clips on. Then select all the files from the Resource tab using Ctrl+A, drag and drop to the movie in Movies tab. <br /><br />Step 3. Choose export format - <b>Panasonic HDC-SD90 MTS to MOV for SmugMug Pro</b>. <br />Click the Export button, and go to the Devices tab. Choose HD Video - H.264 HD Video(*.mov) for conversion . <br /><br />Step 4. <b>Set Video/Audio Quality and Export</b>. <br />To get high quality videos, you can choose 1920*1080 size(pix),frame rate 25fps,medium quality as video bitrate and 256K audio bitrate before starting conversion.The quality loss is not significant, the videos still look great when viewed. Click OK to start <b><a href="http://www.aunsoft.com/final-mate/">Converting Panasonic SD90 AVCHD MTS files to 1080p MOV for SmugMug</a></b>. <br /><br />When the Panasonic SD90 MTS Videos to 1080p MOV conversion is done, you can quickly <b><a href="http://www.aunsoft.com/final-mate/">Upload Panasonic SD90 Recording MTS Video to SmugMug</a></b>. I also keep the MTS files as a backup - these play OK locally in WMP and Popcorn Hour.
on Jun 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
My camera will not zoom
Zoom motor or control assembly is responsible for the issue. If lens removable try another one to see if it is the lens or camera. Shame
Sep 12, 2017 | Panasonic HDC-SD90 Camcorder
This battery cannot be used
sea water will couse rust to form on the contacts get a fibre glass pen from maplins(uk) radio shack(usa) and gently clean the with it that should cure the problem
hope this helps
John
Jun 14, 2012 | Panasonic Hdc-sd90 40x High Definition...
My grandpa needs a new part for his vivitar 55mm. I don't know about cameras so my description may not be great but it is a rubber ring around a plastic piece that screws into the lens. We need to find a...
I think you want a lenshood that is 55mm in diameter (the distance across the front of the lens-what we also need to know is about the lense- what is the wrting on the ring around the very front glass lens? Also, if you l ive near a camera store, take the lens in and they can help you.
May 17, 2010 | Vivitar 35x X3 Telephoto Lens For All 55mm...
Lens
You have a 55mm filter size on your camera, and the accessory lens requires a 62mm camera connection. I think you are looking through a 55mm tunnel into a 62mm lens (over-simplified I know). The black ring is the result, and I don't think you can fix that. Is the telephoto a Panasonic accessory, or a third party item. I think I already know the answer to that. I'd take it back and see what Panasonic recommends - you'd be happier. However, Panasonic has Leica glass (Leitz lenses) so it won't be cheap.
May 19, 2008 | Panasonic Cameras
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Lenses
Focal Lengths for the C-2000/C2020 Zoom Adapter CLA-1 Step-Up Ring F/L+1 +1.6X +2X 2.5X B-Macro Yes Yes (43-55mm not incl. w/lens) N/A N/A N/A N/A B-28 Yes Yes (43-55mm incl. w/lens) 29mm N/A N/A N/A 1.45x 150mm Yes Yes (43-46mm incl. w/lens) 150mm 245mm 300mm 375mm
Sep 01, 2005 | Olympus Camedia C-2020 Zoom Digital Camera
Cameras Logo
119 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
