Plumbing Logo
Posted on Jul 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Buttons on our concealed dual flush cistern have stuck in, water constantly running into pan?
Chris Harvey
Level 3:
Master:
  • Master 447 Answers
  • Posted on Jul 09, 2011
Chris Harvey
Master
Level 3:
Master:
Answers
447
Questions
0
Helped
141228
Points
1166
The ring where the buttons are should unscrew and the full unit should pull out,if that dos,nt stop the water try to gently pull the plunger up, if that stops it push the plunger back in to flush toilet,see if plunger returns to normal position and water stops, if that dos,nt work have it checked out by aservce engineer.
How can I get more water in toilet bowl on glacier bay dual flush
the amount of water in a pan is set by the height of the bend at the back
If you are asking how to get more water to flush the pan, raise the water level in the cistern by adjusting the water control height in the cistern
I have a leak coming through my ceiling from the ensuite toilet above. It is an ideal standard wall hung with concealed cistern behind tiles. There is no obvious access panel. The tiled wall is flush.
The flush control panel normally comes off. You can then hopefully see inside. You won't be able to see much though as the cistern will be in the way...
Places to look for leaks are:
Soil pipe to pan
Cistern to flush pipe
Flush pipe to pan
Cistern overflow.
Apr 17, 2017 • Home
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
SL tank carrier unit just installed last week.work fine the first few times, now water keeps running into the toilet bowl
hey, since it is new, I assume a small stone or left-over is stuck where the seal is, You need to disassemble the valve, clean it and re assemble. Look at this guide that might help you. though it is not the exact model, principle is the same.
Have fun
Avi Grohe GD2 flush system concealed cistern repair fix and disassembly...
Opal 2000 toilet suite, water leaking from around bedding cement. Have marked water level in cistern and bowl with marker and there is no change, water would appear to be coming when toilet is flushed like...
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
2helpful
2answers
Weak dual flush does not empty the toilet bowl.
well, yes... but apart from providing you with a forum in which to vent your frustration I'm not sure how you think we might help. I have the same problem with a dual flush cistern, but in my case I know that the root of the problem lies in the fact that the soil pipe leading from the bowl has insufficient fall (because the previous owner of my house moved the toilet further from the down pipe). Maybe something like this is contributing to your problem too?
2helpful
Push button not operating fully/correctly. cistern flushes sometimes, but not always and is only two years old. It's a Grohe concealed cistern.
hey,
Check your button/s panel, check that the hoses are connected firmly.
Disconnect the hose and blow air through it, does it work now?
If it works ok, you need a new buttons panel. (or fix it).
If problem remains, you need to disassemble the pneumatic valve and check / clean/ repair it.
Have fun
Avi
Nov 23, 2009 • Grohe Home
I needs new valves for my dual flush, close
No I'm sorry they do not. You might try plumbing supply house in your area.
Aug 05, 2009 • Home
Top Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Plumbing Expert? Answer questions, earn points and help others
