I don't have access to the security codes for car radios, including Becker Indianapolis Pro. These codes are usually unique to each device and are intended to prevent unauthorized access to the radio.
However, you may be able to retrieve the code for your Becker Indianapolis Pro by contacting the manufacturer or a local car dealership. They may require proof of ownership, such as the car's registration or your identification, to verify that you're the rightful owner of the radio.
Alternatively, you can also try searching for the code using the radio's serial number on online radio code databases or forums. However, please note that these methods are not always reliable, and you should exercise caution when using them.
Is there not an online site you can go to and get the code. It might cost you a couple of bucks?
I've just put your serial number into a UK based site and its come up with the code for $10. See if there's a US site?
You have to put in the whole number; BE462338028733.
Just search "Becker radio codes"
The radio SERIALNUMBER will be required for calculating a code
On some radios, pressing Buttons 6 and 1 or 6 and 2 (together) maydisplay a Serial Number
If not , then removethe radio from the dashboard.
Then post all the letters+numbers on any labels,barcodes or stamped inthe metal casing.
This information canthen be used to see if a code can be calculated
