Washing Machines Logo
A
Anonymous Posted on Jul 09, 2011
I have an IQ touch front load washer. lately I have noticed a mildew smell coming from the clothes and drum after washing. i have followed the manual and completed the refresh and comlete cleaning instructions. The clothes are not sitting in the washer after the cycle but going directly into the dryer or hanging. nothing seems to the smell. any ideas?
Anonymous
Level 2:
  • Expert 244 Answers
  • Posted on Jul 09, 2011
Anonymous
Expert
Level 2:
Answers
244
Questions
Helped
76044
Points
566
Water can remain in ANY washer after the load is done. With a top-loading washer, it's easy to leave the lid up so that the water evaporates. With a front loader such as yours, however, the open door can take space in your laundry area, so we usually close the doors. I suggest that you take a dilute solution of chlorine bleach and water and put it on a disposable cloth and wipe down the inside of your washer as well as the areas around the door itself and the part of the washer that the door closes onto. Once you've done this, leave the door open until the smell dissipates OR overnight. If you will get into the habit of leaving the door open for a couple of hours after you're done with your laundry, you will probably solve the problem.
I really hope this helps. If it does, please come back to Fixya and rate my solution.
Constant mildew smell from washer
Visit this site and read this article:
http://homemanagement.suite101.com/article.cfm/washing_machine_odors
Assuming the drainage isn't a big issue, the vinegar trick seems to work best...you may have to do it more than once if it's really bad.
7helpful
Washer makes clothes smell like dog
Hello there:
please follow these simple steps
Instructions Things You'll Need:
  1. Step 1 Balance your washing machine. Standing water breeds mildew and mold. A washing machine that isn't level to the ground stands a higher chance of not draining completely. Take a level and place it on the top of the machine along the front from side to side and then again along the side from front to back. If the machine is very off, you can adjust the feet to compensate or add something under one of the feet if it is not flat against the ground. Portable washing machines are especially prone to have standing water because they are moved around and not leveled each time.
  2. Step 2 Promptly remove your clothes at the end of a wash cycle. If you regularly leave the damp clothes in the washing machine for an extended period at the end of the cycle, you will have mildew in your clothes and your machine. The same is true if you put clean clothes in the dryer and they are not completely dry when the cycle ends and you don't go back for a few days to pull them out. Damp clothes in an enclosed space for days will mildew.
  3. Step 3 Leave your washing machine door open in between uses which gives the machine the opportunity to fully dry out.
  4. Step 4 Use white distilled vinegar in an empty machine. Run a load with only hot water and two cups of vinegar to clean out the machine and freshen the scent. Vinegar naturally eliminates odors and reduces the buildup of soap residue in the washer which contributes to mildew development. You can also add baking soda and/or bleach to the load for both their sanitizing properties as well as assisting in ridding the smell of mildew.
  5. Step 5 Regularly use vinegar when you wash your clothes. Add 1 cup of white distilled vinegar to the last rinse cycle. Vinegar has acidic properties but it is mild enough that it will not harm your fabric. It does dissolve alkalines in laundry detergent which makes for cleaner and softer clothes. The reduction of detergent buildup in your machine will help to also reduce the incidence of mildew.
  6. Step 6 If you have a front load washer, they are particularly prone to mildew and mold. Follow the manufacturers suggestion as to how much and what type of detergent should be used. It is generally less than the traditional top load washing machines. Once again, additional soap residue helps to breed mold and mildew. Also, pull the seals back from around the door and make sure there isn't a build up underneath them that needs to be cleaned out.
  7. Step 7 Finally, if you have done all of the above and nothing seems to work there are commercial products available that are recommended.
1helpful
Sud message on whirlpool duet front load washer also after washing clothes i notice a mildew smell on the clothes.
You areusing too much soap. Run a rinse cycle and use less soap next time. As for the mildew leave your door cracked open after you are done using the machine.
1helpful
Smell of mildew on our towel and sheets
This is probably happening because the clothing is being left damp in the washer. When it is warm during the summertime mildew will grow very quickly in the towels. On front load washers you need to leave the door open when not in use to keep mildew from growing. You should wipe out behind the inner seal any moisture when you are done doing laundry. This is an issue for most front loaders. Some front loaders have a clean washer cycle that uses bleach to sanitize the drum. Other washers like the Samsung have a block of silver and release silver ions in the wash to sanitze the clothes.
Hi, I have a hoover front loading washing machine and inside the drum seal there was a lot of mildew as I accidentally left some damp tea cloths inside the drum and the machine wasn't used for 2 weeks....
Run your washer with 2 cups of bleach, maximum hot water. After it starts agitating for a minute, stop the washer & let it remain for 2 hours. Then continue the wash.
1helpful
2answers
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Mildew smell on clothes
I have the same machines. Try using an old towel and detergent solution( use rubber gloves) and thouroughly clean the door seal. It can be just full of old lint, dirt, etc. in the grooves. Also try some oxyclean in your next load. That will help get rid of the odor also. These washers stay warm quite a long time and clothing will mildew fast in warm weather, but you probably already know that.
Two problems, mildew smell and loud noise in spin cycle
drum bearing failure due to the water seal in front of the bearings failing the smell is probably the grease mixed with water in the outer tub
Smely Clean Clothes
We had a similiar problem. It was mildew in the washer and in the fabrics. We ran two or three empty loads with some bleach added in, and we leave the door open so the drum dries.
The towels and clothes we hung out in bright sunlight. The UV rays kill the mildew.
2helpful
All washing just smell worse when washed
there is water laying flat somewhere that will not drain completely. thoroughly check the drain hose in the back...any kinks?
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
