SOURCE: does not print. Asks for output file instead.
The default printer is set to be "file". Here's what you must do:
- Go to printers dialogue box and right click on your printer name and selectd "Set s default printer"
- Right click on printers name and chose Properties. then look for a check box saing something like "print to file" and unchek it.
This sould resolve the problem.
Best regards
SOURCE: HP DESKJET 5650 - DOES NOT PRINT ON ANY PAPER
Hi dear; When you put in the new cartridge ,did you removed the plastic seal(tape)?
SOURCE: Mac not printing to HP Deskjet F2200 series
1) First let's make sure the hardware is working. Place a document face down on the scanner glass. Press Start Copy Black. Did it scan and print?
If not, please let us know.
If it did, go to the next step.
2) Please confirm the USB cable is plugged firmly into the back of the printer and to the computer. Do not go through a hub, switch, or router.
3) Click on your Apple icon (upper left corner), System Preferences, Print and fax.
Do you have the F2210 printer listed more than once?
I am going to suggest removing the F series printer. Highlight it and press the minus button to delete. Once you have removed it, close all windows back to the desktop.
On the computer click on Hard Drive > Applications > Hewlett-Packard > Device Utilities > HP Setup Assistant. Follow the on screen directions to add the printer back to computer. Do not re-register the printer (choose skip or register later). Once your are able to click finish, try printing again.
I would suggest trying to print from Text Edit first. This will rule out any possible issues with the Word document you were trying to print. Click on Hard Drive > Applications > Text Edit. Type your name in the untitled screen. Click on File > Print. Make sure the F2200 series printer is selected. Click Print. Did it print?
SOURCE: HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
SOURCE: Why there's some stripes appear between my print
printer hp color laserj c1515n problem color print dim not clear print
plz soloution
