SOURCE: dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
SOURCE: Describe your Dewalt & 14.4V Xrp
Hello. I can help you. Your motor is producing the smoke. Before more damage is done I recommend taking it or sending it to a Dewalt sercive center.
SOURCE: Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
SOURCE: removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
SOURCE: Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Testimonial: "Thanks for your help! It looks like there is still some live left on the brushes...I guess I was just overly concerned! :)"
