LG Neon GT365  Cell Phone Logo
Posted on Jul 09, 2011
I got a new used at&t lg gt365 and when I put my sim card in it nothing happens when I hit ANY button... menu, options, camera, keypad all buttons! I cant make any calls all though I can get incoming calls but can NOT answer it! Is the phone locked or broken?????
4 Related Answers
Anonymous
  • 282 Answers
  • Posted on May 19, 2008
SOURCE: LG Shine key pads not working at all!
Possible any of your keys are sticked. may be on keypad or in side keys. Check those first.
Anonymous
  • 4 Answers
  • Posted on Aug 04, 2009
SOURCE: LG VU Keypad Locks after 2 seconds
Hi i have the same phone and i had that problem. Have you tried going to settings then click the more button then click security and Auto Screen Lock. There are 5 options you can choose from click off and that should fix it.
Anonymous
  • 6 Answers
  • Posted on Aug 02, 2010
SOURCE: My w910i does not autolock
your phones flex ribbon is worn out
Anonymous
  • Posted on Oct 03, 2010
SOURCE: LG KM900 Screen goes black when it rings and can
If you have a screen protector on, the proximity sensor is covered by the screen protector. The sensor is locate on top left of the screen next to the inner camera. Cut of the piece of screen protector and it should solve the problem.
I have the code to unlock my phone how do i put it in i have a lg gt365 neon
You need to insert sim card from network which is phone currently working and enter unlock sequence mode 2945#*365# . Then you get a hidden menu where you can enter unlock code.
4helpful
2answers
I bought a unlock code for my lg gt365 neon and i put a tracfone sim card in it and it says emergency calls only how do i fix it so i can use a tracfone sim card.
First you need to unlock your phone before you put tracfone sim card on that phone. Make sure you have appropriate LG neon GT365 unlock code example : if your old sim card using t-mobile you must use t-mobile unlock code for your phone not tracfone. You can get lg unlock code from online seller with lower price and quick turnaround.
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
2answers
My phone is sayin puk blocked
If your personal unlock code is blocked you have to call customer care. Have the IMEI, serial number, and SIM id ready along with your account information.
2answers
How can i get my subsidy unlock code of GT365 neon if i attempted in ten times. i cannot access now
its not possible. ur gunna have to call ur service provider and get a new sim. the same happened to me today with the same PHONE!
2answers
How to fix an invalid sim card
try a different sim card if that doesent work then it might be the phone
My mother got an LG Neon GoPhone. She's been using her SIM card on it and it's been working just fine, but when she activated the SIM that came with the phone and tried to put it in the phone, it says...
It's normal since your phone still locked. You must unlock your phone first with lg neon unlock code for your phone network carrier. This code will reset your phone network to default factory setting so you can put any sim card on that phone. Lg unlock code can be purchased at third party sites on internet.
I bought a new AT&T Go Phone and put my old at&t sim card in it and it worked for three days. Now I get a sim card not provisioned mm#2 message.
Maybe you need to unlock your phone network with lg neon gt365 unlock code for at&t network. This code can reset your phone network to default factory setting so you can easily change your sim card with other sim card even form other network provider. To get lg unlock code you can purchase at third party sites on internet.
3answers
I didn't have sim card in the camera when i took photos now
I recently noticed a mini SD memory card in my cellphone and even though there was data on the chip which I had put there using the SD adapter and my laptop none of the data was viewable on the cellph screen. I went ahead with the Format command on the cellph. It erases my data but I believe I will now be able to store multimedia to the SIM as the Good Lord intended.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
