Vizio VSB210WS Soundbar Logo
Posted on Jul 09, 2011
New vizio tv and vizio sound bar,I have sound from tv but no sound bar sound.
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Dec 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
11859
Points
11
Get to your menu on the tv and click your audio, go down to speakers and turn it to the off position.
2answers
How do I set up my vizio vsb200 sound bar to my sharp tv?
1. Plug in the power cord.
2. Plug in the optical cable from your TV to your sound bar.
3. Turn on your TV.
4. Turn on your Soundbar.
5. Check the audio on your soundbar and make sure it's set to the right input.
Guide attached:
How to hook up a vizio sound bar to a auria tv
Read the user guide that comes with the sound bar. The bar has an optical link and RCA input jacks. The Auria TV should have RCA output jacks, so get a paired cable set with red and white RCA plugs on both ends. The input button on the sound bar will select the connected input when pressed.
2answers
On the Vizio D TV's......the quality of the sound is horrible. It sounds equivalent to a 1970's 12 TV!! Did we miss something when setting it up?
Hello, Kim -
I found the following evaluation of the sound quality for the Vizio D television from the Rtings.com web site:
[Quote]
The sound quality is sub-par, and the TV doesn't get very loud. You will definitely benefit from having a separate sound system. Even a cheap sound bar would be an improvement.
[End quote]
So, you probably didn't make any errors in setting the TV up and may need to purchase a sound bar or speakers. We have an older model Vizio TV and found the sound quality is improved with added speakers. Our speakers can work as a sound bar or 2 speaker units on each side of the TV.
Vizio tv sound to speaker outlet dead
Connect the sound bar to the cable box audio out.
We are trying to hook up a VIZIO sound bar model#S3820w-Co to our Vizio TV we also have Directv and a dvd player hook to this tv which wire do we hook from sound bar to Tv
If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
1helpful
HOW DO I CONNECT MY TOSHIBA TV TO A VIZIO SOUND BAR?
Take it back to where you brought it from, End get your money back. End get a sound bar with a optical jack on it,
Dish Network VIP722 and a Vizio VHT510 sound bar.
Try connecting a optical audio cable out from your TV to your sound bar and directly connect your 722 to your TV with HDMI.
Top Vizio Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
