That often happens as a result of a short on this model. Try emailing them at this site: www.camerasandparts.com They service the Canon Powershot cameras exclusively and they do excellent work, all for about half of what Canon wants. If you need help with it, that site is the place for a Powershot. They are excellent, send them an email and I'm sure they can help you with this problem. Good luck.
Take out memory card from camera, and connect memory card to computer using a card reader, then use this memory card recovery software called asoftech data recovery
http://www.asoftech.com/adr/
Hi,uskudarlikiz! You can recover your lost images from your Canon Powershot G7 with a Canon Photo Recovery program: http://www.canon-photo-recovery.com/ Best wishes!
You are aware (aren't you) that the G7 cannot use the new 4GB or higher SDHC cards? It was designed before these came out (that's why that 8GB keeps failing). You can only reliably use 2GB or less standard SD cards. Also, do you by chance "format" your standard SD cards cards, in your camera, as recommended in your user manual?
