SOURCE: Humidity-Controlled Crisper Drawers
If you will post the complete model number including the string of digits starting with P, (if it has these) I will look it up and see what I can find.
You can usually go to sears.com, click on parts, enter the model number from the fridge decal, and pull up a parts diagram of the fridge.
Thanks/mike
SOURCE: Amana TempAssure
heres a link to your owners manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/12642722.PDF
SOURCE: Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
SOURCE: Broken refrigerator drawer support pin
I have a Kenmore 2 door,freezer on bottom, mod# 795.77309600,the shelf that holds the crisper draws cracks,front & back corners, also the back,middle. this is the 2nd time for me. Is there a solution??
