Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
Posted on Feb 28, 2018
My PSP 3000, hacked, wont identify CSO or ISO files in the memory stick. I put the CSO and ISO file inside the memory stick inside PSP/GAMES but when i turn the psp on the only thing that it shows in the game,memory stick is my hack file. i have firmware 6.39-PRO B7, pleas help please
Waseem Qureshi
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 40 Answers
  • Posted on Oct 18, 2019
Waseem Qureshi
Contributor
Level 1:
New Friend:
Night Owl:
Answers
40
Questions
0
Helped
13844
Points
70
Kindly Install A New firmware, You can find it on
https://pspbirths.blogspot.com/p/custom-firmware.html
Back Up your Data before installing firmware, Copy only 100% healthy ISO and CSO Files in Memory Stick. Kindly leave a feedback if it helps to solve your problem.
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Jun 27, 2008
SOURCE: CSO File
make sure u have software on the psp tht can run the cso/iso file
a raw psp w/ official firmware wont beable to tun those
wht is the firmware on ur psp
Anonymous
  • 30 Answers
  • Posted on Jan 04, 2009
SOURCE: iso/cso won't run to PSP version 4.20
You cannot play .iso or .cso files (or any homebrew games) on your PSP unless you have firmware 1.5 or a custom firmware. Any "off-the-shelf" firmware such as 4.2 will not support these types of files. They will just show up as "Corrupted Data".
You can go through the process of downgrading your firmware from 4.2 to 1.5, then from 1.5 you may upgrade to a custom firmware such as 5.00 m33-4. Doing so would require a good deal of technical know-how and a LOT of patience. If you do not want to risk ruining your PSP, do NOT try this. Research methods of downgrading such as "Pandora's Battery" and other firmware downgraders.
You were able to download games from the PSP website because they are programmed to play on the current firmware. Even if you were to (somehow) properly convert the .iso or .cso files to an EBOOT.PBP file, it would not run unless you have firmware 1.5 or custom.
Brian B
  • 67 Answers
  • Posted on May 23, 2009
SOURCE: Is it true? Datel Lite Blue Tool can hack PSP 3000 series?
read about dark alex if there is a way to hack a 3000 he'll do it first just search that name on google his site should come up first
Anonymous
  • 25 Answers
  • Posted on Jul 26, 2009
SOURCE: How do I downgrade my psp 3000! (5.51-5.03 or lower) please Help!
yow... i have a psp3000 with a currently working hack... find in the internet a hack called chickHEN... i'm sorry but i don't remember where i found it.
Anonymous
  • 1570 Answers
  • Posted on Jan 05, 2011
SOURCE: can i run iso and
Yes but by installing custom firmware but i don't want is compatible for your psp 5.50, i know only original firmware 5.03, Here is my blog on how to install cfw gen-c and chickher r2 to be able to play iso/cso games. http://www.fixya.com/support/r7119752-install_cfw_5_03_gen_c_9_full_psp
I have many games but when i open the memory stick there are no games..i eject the card then i put it back, but there's no games at all : (
If it is CFW make sure the ISO/CSO files are in X:/ISO folder and .pbp files in X:/PSP/GAME folder. Another tip backup all your saves/ games data etc from the memory stick. Then on the psp go to System>Format Memory Stick it will delete everything on your psp and make all the file errors be corrected.
5helpful
2answers
Memory stick games not working. When i press button on it, the logo appear but it will stay freeze.
First of all, there is no way you can run games off the memory stick. It has been confirmed by several websites that psp hackers are able to extract the whole PSP game onto the computer and burn an ISO to CD/DVD. To answer your question, even though the PSP games are in ISO format, they are non-playable on a memory stick because the PSP checks for a boot file normally from a UMD disc the memory stick doesn't have. click here to download repair guide
1helpful
How can i install iso/cso to my psp 3000 version 5.55
From the root of your memory stick (MS), create a folder named ISO.
Save all your ISO and CSO games there.
Note that your PSP must be hacked before you can be able to play games from the MS.
HOW TO PUT GAME ON MEMORY STICK PRO DUO
Thank you for using Fixya!
If you have a PSP that has a custome firmware then it easy to put games on your memory card. First you need to download the iso or cso file of each game you want. Then connect your PSP to your computer using a data cable and then put the games on the ISO folder of your mem card.
If you have an official forward from sony let say 6.x and above, unfortunately this cannot be hacked at this moment.
If you have a PSP that has firmware 5.50 and below then there is a possibility you can hacked this. Search google there are lots of links tutorial as well as youtube.
Sincerely,
stif_nec
3answers
PSP (Modified 3000) wont transfer game files I download, yet movies transfer fine and work. What am I doing wrong?
You sure the games that you've downloaded are working properly & suitable for your PSP & your version?
Make sure that you have a folder called ISO in the root of your PSP. Drag & drop game files in there!
Games doesnt show up after putting it into the memory stick. Tried iso and cso file types
This isnt a problem as you would not have a custom firmware installed on ur psp you can get it from psp-hacks.org
2answers
Corrupt files
Make sure that when you download the games and/or movies, you use winrar and make sure that you put them in the right folder.
3helpful
2answers
I cannot put my cso files into the psp
First of all what psp is this is this the PSP 3000?if it is you canot put any cso or iso games in it because it cannot be hacked
but if it isnt try finding a different source of that file and i suggest you just go with iso type games cause it is complete cso games are smaller but they cut some parts of the game to make it smaller
BIG HELP
is your PSP modified/CFW? if not it wont play cso or iso games. When u formatted your memory stick it will create ISO folder in the root of the memory stick. you said you created the folder, sounds to me that your not using CFW. this wont work.
If your using CFW/modified then format your memory stick using format option of your psp. Copy the cso/iso files to the ISO folder and that should work.
Cannot play downloadable game to psp 3006
it's because psp3000 can not read downloaded games because it is in iso or cso formats, as far as i know, no one haven't hacked games for psp3000, lets pray there will be one!
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
