Hi If
refrigerator is not cooling properly it can be due to a defrost timer, which is
causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for
refrigerator to come out of defrost cycle. If the timer
is bad then it will not come out of defrost cycle and
can result in this kind of issues. It can also occur due to defrost thermostat,
it allows current to pass through it at temperatures of 20 to 30 degrees
Fahrenheit and prevents current from passing through it at 40 to 60 degrees.
This is difficult to test, though, because it takes a prolonged, very-cold
temperature to turn it on. The defrost thermostat is
snapped onto the top portion of the evaporator. The thermostat sends
temperature information to the processor. The defrost heater must be replaced
when replacing the thermostat. Hope this helps...please post back for further
assistance. Daniel
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
It is in the back and yes you are right it's evaporator
cover. However, I've provided you the procedure to replace the defrost thermostat.
If you're not well versed with the repair of refrigerators then it is always
recommended to contact a qualify tech to perform the repair/replacement process.
If you are well versed with the repair then I can provide you the instructions
to replace the parts.
you too
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check
Refrigerator
not Cooling
Timer Problem
Water
from Freezer
Refrigerator
heatman101
Re 1. Remove the lower fan duct work from the evaporator cover.
Is this in front or back?
We removed back plate on bottom right hand side... Is this evaporator cover? We see black compressor on right... fan on left... only 1/4 inch screws l;eft are on late covering line to ice maker.
Not sure what we should be looking for from that. Do you have a picture?
Thanks. We'll find a repair man. Have a good day.
