SOURCE: KV-32FQ75E colour loss
Go to the Sony website and check out the correct antenna cable and scart lead configuration for your set up. I did and with a few simple connection changes it was like getting a new TV.
SOURCE: where can I buy remote
Before you buy another remote try this; This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to Step 4- Put the batteries back into the remote, being very careful to install them correctly. Step 5- Try the remote. Special Note: If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
New batteries should be used if you're not sure about the old ones.
If you do then the problem might not be the remote but the sensor on the set.
