SOURCE: Yellow line on edge of page
on a ricoh - that would be the pcm - photoconductor module on an ecosys the module should last 100,000 pages nothing ever seems to last that long send an email to http://www.pcandl.com/ or call where you bought it
SOURCE: printing problems
Hi there check that it isn't the drum unit by turning the machine off open the top cover remove the toner and underneath you will have the dev unit unplug and lift out then remove the transfer tray (the one you open if there is a jam) open side door remove waste tank then you have the drum unit now to remove there is either a push button or a screw do either one that corresponds and check the unit. If there is a black line on one side the only way to get rid of the line is to replace the cleaning blade as this has worn. you can clean the drum unit cleaning blade it may only be toner stuck under the blade all you have to do is rotate the drum the opposite way of operation and if you have to hand a air line just give it a blast failing this it will defently need replacing.
Hope this is of some help
Please rate me
Cheers J
SOURCE: kyocera printer problem
First I would recommend cleaning the printer. When you change the toner there is sheet of paper that comes with the toner cartridge that explains how to properly clean the printer. If you do not have that handy, there is a panel on the left hand side of the printer that you need to open. Once the panel is open you will see the waste toner bottle; leave it in place. Above and to the right of the waste toner bottle will be a green nob. Pull this green nob slowly in and out three or four times. This will clean the charging wire. Next underneath the green nob there should be a piece that looks like a rectangular box when you pull it out. I believe it is green as well. This is the charger grid. With each toner you should have gotten a small slate blue box with a plastic lid that has a piece of felt under the plastic lid. Remove the lid and this should slot in under the long, rectangular charger grid. Move this back and forth three or four times and than remove the slate blue box. Gently push the charger grid all the way back in and close the access panel.
If this does not fix your problem I would recommend getting service from wherever you purchased the printer as you may have damaged the drum.
Let me know if you have any further questions.
Henry
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
SOURCE: Kyocera FS-2020D won't print
You have to go to setting to change the cassette paper size , what happen is : in the setting that cassette has different size value, so when you try to print A4 it ask you to load it in the bypass or the Mp. all what you have to do is: go to cassette setting or comon setting and change the cassette siz to A4, and it will fix your problem.
Thanks for using Fixya
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
