Hi - it would seem the washer pump may actually be blocked for some reason... If you had followed the method as per the diagnostics then if you reckon you got 35 then its a communications error beween the console & display. Furthermore you would be able to mannually start the pump in diagnostic mode to see if its working fine.. But under normal cond..... the machine would come up with a pump error & code 37 - so perhaps it is ok.
Remedy - check the harness wire connections between the display & the controller unit is good - clean - otherwise replace the display unit to correct.
On the error codes - there is a Code 35 - just that its not available to the public - it was only ever issued on a DVD sent to the service agents - have never actually seen it on the secure service site.
See how you go....
