HP LaserJet 4350dtn Printer Logo
Posted on Aug 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Laserjet 4350dtn Print Quality poor
The quality of documents (B & W) is poor. There seems to be vertical strips where the quality suffers. It just seems faded. Does this mean I need a maintenance kit?
steve shroder
Level 2:
  • HP Expert 141 Answers
  • Posted on Aug 26, 2008
steve shroder
HP Expert
Level 2:
Answers
141
Questions
Helped
61725
Points
244
Most likely the fuser has lost part of the teflon from the heat roller. Having said that, the first step in any print quality issues is to change the toner cartridge. good luck!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
722
Points
I am having the same issue and have changed out both components as you did with no luck.
Anonymous
Level 1:
  • Posted on Jan 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
722
Points
I have change the fuser & the toner and still printing light any other solution
How to solve hp laserjet 4350dtn fuzzy print?
usely it's the fuser sleeve the problem. replace the fuser but before be shure the cartridge is ok. print something and open the cartridge door when printing to see under the cartridge the print quality if ok replace the fuser unit
1helpful
Poor quality on LaserJet P2015n Printer. Doesn't print Black only in Gray tones.
Problem with cleaning blade,which fails to clean properly on surface of the drum..Replace it..
2answers
I have purchaed HP toner cartridge 13A from Computer Shop. But print quality of ink is poor. So, how to increase more quality of ink.
Hi
For increase the print quality go to the printer properties and go printer preference and select the device setting and set your setting.
1helpful
Poor print quality of images on envelopes
clean the print head 3 times,then realign the head .these are done by printer utility software given with the printer.
Even not ok.
Then Replace the New Catridge.(manufactured from within 3 of 4 months).because the ink will be dried with in 6 month.So Buy Carefully with Mfd Date.
Thank you
About 15mm dark hadow vertical line on the page.
Sounds like its time for a new drum/print cartridge. When it get worn you start to get poor quality prints and sometimes lines. COule also be scratched and transfering the line on the prints but in either case needs to be replaced.
Poor, faded print quality on left and right sides of paper
Have you check the teflon at the heater? have you clean the reflector of laser? Try that.
1helpful
Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
99% of printed page has light grey water mark-as if water-washed
Are you saying it is this problem?
Gray Background Print Quality Defect
Here's another error that might fit the bill:
Vertical Lines Print Quality Defect
If these documents don't quite describe the issue, please post back with more details. Thanks.
k24674
Grand Canyon Tech
Grand Canyon Tech
