Insignia 37" LCD Flat-Panel HDTV Logo
Posted on Jul 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AFTER A LIGHTNING STORM MY 37 INCH INSIGNIA TV HDMI INPUT HAS A NO SIGNAL. CAN YOU TELL ME WHAT THE PROBLEM IS? IT WORKS FINE THROUGH THE COMPONENT INPUT.
Electro Med Services
Level 3:
  • Insignia Master 6,694 Answers
  • Posted on Jul 11, 2011
Insignia Master
Level 3:
Answers
6694
Questions
Helped
1870185
Points
21433
Hi
Its tuner has been damaged. Lightning stroke will have Trillions of volts when it hit the earth. No electrical houlhold equipent can withstand it. Evan a part of it is efficiant to damage the tuner and other sections of a TV; designed to work with 120V or 220VAC. The induced voltage that came through the cable of by the antenna, surely had damaged your TVs tuner. If tuner has been damaged, the set will not get any signal to process. According to your description, all the other sections are working now. Otherwise you won't get any screen at all. Get it repaired by any experienced service technican or by the Authorised Service Center for Insigina at your town. If you are able to, you can do it yoursef. But after tuner replacement, some adjustments may have to be done. If you have knoledge in digital electronics, measuring equuipments, and a concept of soldering, dare to do it. Otherwise it will be best to get it repaired by any experienced service person. OK
2answers
Insignia 37 inch....no sound after lightning storm and HDMI's are not working
Dude! You fried it! Sound board can be replaced, but what else was stressed? Replace it, use a good surge protector, and turn the thing off during storms, light a candle and cuddle with your sweetie.
4helpful
2answers
Only one (out of four total) HDMI input is working on my set.
The HDMI switcher IC chips in TVs can be damaged but lighting hits near you house even if the power is protected with a surge protector. The damaging power comes in through the HDMI port and blows the chip out and it can affect just one port or multiple HDMI ports. Your best bet would be to just get a cheap HDMI switcher and use the one working port. The repair on the TV would require placing the control board and would run from $75-150 for parts plus the labor to install it.
Lightning Storm messed up one HDMI Input
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1helpful
HDMI no longer output after lightning storm. ps3 still has all the data and can still output in composite. tried resetting and reboot and still not working
I would try another device that uses HDMI output and plug it into that HDMI tv input to ensure that it is not your tv that is at fault. If the TV is fine, more than likely something in your PS3 got fried. This is actually a common issue with the PS3 as you can see here:
http://www.ps3chat.com/playstation-3-hardware/7353-lightning-storm-ps3-hdmi-stopped-working.html
If your tv is fine you will more than likely have to call up Sony for a repair or a replacement. Lightning can do damage to any electronic device from up to miles away. EMF damage is a nasty thing. It used to wreak all kinds of havoc for the wireless internet company I used to work for.
I hope this helps! If it does, please give it a thumbs up!
1helpful
Lightning storm and all hdmi connections stopped working
It may be a problem with the DVRs. You can rule that out by connecting a different HDMI TV to one of the DVRs.
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Blue ray wont play movies on new tv
Are you sure the tv is 1080p capable? Usually when "mode is not supported" is displayed, it means that the tv can not handle the signal format that is being input to it. If you are using HDMI, then signal formatting is usually handled automatically. If you are using component video, you will probably have to tell the PS3 to step down the signal to either 1080i or 720p.
1helpful
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Hd tv
My HDMI has stopped working. I have had a technician from Dish network out to my house 3 times and they have replaced the receiver and the HDMI cable and were unable to get the set to work all I get is a blue screen and a message which reads no signal. I also cannot use mt set using 3 rca cables connected to the component input when set to 1080 I keep intermittenly get a black screen then a blue screeen and sometimes a no signal message. I have to watch the tv set to 720 on component 2 and it is the most stable in that setting. Please send help
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
