SOURCE: How to Copy my files from my L6 cell to computer?
Hi Pls, have you tried USB Data Suite [MA-8870] for Motorola SLVR L6? Are you using MA-8870 USB Cable Device Driver & Modem Driver? Maybe you can try downloading these at http://global.mobileaction.com/download/download1.jsp?phoneBrand=13&modelID=496 and see if it works for your L6. Hope this be of some help to you. Good luck and pls post again how things turn up. Kind regards.
SOURCE: A920
wher to get the programes well if u by it u should have the cd cet up sp u can use those facility for your ph or use bloot or ifra if u have bloot on your comp it should pic your ph up then u can trensfer files true bloot... or ask in the shop if they can order the cd set up for your ph good luck
SOURCE: i have a cell motorola w385 and i need to download pic to compute
You can try setting the USB mode to memory you may also need to obtain a copy of Motorola Phone Tools
SOURCE: download texts messages onto computer
You will need to download a software called mobile phone tools to get this done. You will also need a data cable or a bluetooth dongle on your PC so that you can connect the phone. http://www.bvrp.com/ENG/products/
After downloading and installing the above software follow these steps to transfer the msgs to PC.
Open Mobile Phone Tools
Press F3 (for transferring messages from outbox) or Press F4 (for transferring from inbox)
Select messages you want to transfer
Select EXPORT
Choose format/destination. I would recommend txt format as it is real quick.
Hope that helped,
Sai.
SOURCE: Download photos from phone to PC
well check if it has a micro sd card or usb data transfer cable if not you can try sending through a text to your email adress hope this helps
