If your Sony DSC HX1 camera appears to be working, but you can't see anything through the viewfinder or LCD screen, there are a few possible causes for this issue:
1. Display Settings: Check the display settings on your camera. There may be an option to switch between the viewfinder and the LCD screen. Make sure the correct display mode is selected.
2. Viewfinder/LCD Switch: Some cameras have a switch or button that allows you to toggle between the viewfinder and the LCD screen. Ensure that this switch is in the correct position for the display you want to use.
3. Display Brightness: It's possible that the brightness of the viewfinder or LCD screen is set too low, making it difficult to see the image. Check the camera's settings menu for options to adjust the brightness or contrast of the display.
4. Faulty Display: If the above steps don't resolve the issue, it's possible that there is a problem with the camera's viewfinder or LCD screen. This could be due to a loose connection, a damaged cable, or a malfunctioning component. In such cases, it's recommended to have the camera inspected and repaired by a professional technician or the manufacturer's service center.
5. Power Saving Mode: Some cameras have a power-saving feature that turns off the display after a certain period of inactivity. Check the camera's power-saving settings and make sure the display timeout is set to a reasonable duration.
If none of these solutions work, it's best to consult the camera's user manual for specific troubleshooting steps or contact Sony customer support for further assistance. They will be able to provide you with more detailed guidance based on the specific model and issue you're facing.
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Further research indicates this is a common problem with JVC camcorders.
If it were a car there probably would have been a factory recall. I'm sending it to JVC Service,1500 Lakes Parkway,Lawrenceville,GA 30043 for repair.
If you get a blank LCD, dimly lightened by a whitish back light, then the LCD display eis either faulty, badly connected, or the ribbon connector to LCD is defective. The camera must be taken apart, ribbon cable tested, and eventually replaced and adjusted. If all contacts on ribbon cable return continuity (cable is fine), then LCD is faulty, and must be replaced. Althought the job is not too difficult, an user without experience may damage the camera in attempting this repair. My first suggestion is always taking the unit to a camera shop.
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
there is no "display" button on my camcorder
