The following page has instructions and a link to a video:
http://waterheatertimer.org/Replace-anode-rod.htmlHow to:
Rods are installed in top of tank.
Most are located under a 2" round plastic cover located on top of tank.
Some anode rods are connected to hot water nipple
Read
owner's manual to see location of anode rod
See list of water heater
manufacturers and brands to find product manual.
Before
starting, turn off heater source: electric water heater: turn off circuit breaker; gas water heater move control knob to pilot.
Close shutoff
valve on cold water side of water heater
Open bathtub faucet to relieve pressure and let air into water
line.
Open drain
valve near bottom of tank,, and
drain 2 gallons of water.
http://waterheatertimer.org/Water-heater-will-not-drain.htmlUse 1-1/16" socket for hex head rod
Rod will be rusted in place, use
generous amount WD-40
WD-40 spray is flammable and
will burn
so be careful around heat source.
Loosening rod: go slow and check that
water does not seep up when loosening rod because hot water can
spew out hole if tank is very hot ... it is important to drain enough
water out of tank to avoid accidental scalding.
Install
new anode rod: One source says/ use
pipe compound on thread instead of teflon tape. Other sources say use
teflon tape. Either way, tank metal and anode metal must meet, so rod
will
work.
