Whirlpool GH7145XF Microwave Oven Logo
Posted on Jul 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
@What is the reason for arching - Whirlpool GH7145XF Microwave Oven
Ismael Rodriguez Batista
Level 2:
Habit-Forming:
  • Expert 188 Answers
  • Posted on Jul 12, 2011
Expert
Level 2:
Habit-Forming:
Answers
188
Questions
Helped
79914
Points
279
The paint in side is coming off and the metal is espose do not use any more.
tip
What to do when the microwave is arching.
Hi.
If your microwave cavity is crossed by luminous discharges of current , and you see flashing arches of current from the magnetron area to other areas of the microwave oven cavity, then we commonly say that the microwave is arching.
The first thing to do in this case is disconnecting power immediately, and trying to remove the cause of arching if possible.
Arching will damage the microwave oven, if it goes on for enough time.
Any metal conductive object, such as a spoon or a fork will cause arching if left inside the oven when the microwave device (the magnetron) is operating.
Ensure that there is no metal object inside, while the appliance is operating.
Some vegetable with an high amount of metal , and some other ingredient, like bacon , are known to cause arching in sporadic cases.
In that case add a little water to the food in the oven and try again.
Sometimes recycled paper, or use of containers that are not for microwave can also cause arching. In that case use a different container, or paper.
If there is arching and bad burnt-plastic-like smell with any food being cooked, that means that there is a major problem, and that if the oven is used in this condition, you may get further damage to the appliance. In some case there may also be safety concerns.
As said, you get arching inside microwave when inside the cavity there is a strongly conductive object, such as a metal object or carbon residue.
You also get arching when the oven cavity is damaged.
In this last case the cavity may have lost insulation, and it is better having the oven repaired by a technician, that will also conduct a radiation leak test on the appliance to prove its safety.
To attempt fixing the problem by yourself , you can do the following:
Disconnect power cord.
Check inside the oven cavity, ensure that there is no foreign object inside (such as a small screw). Check also under the turntable.
Check that the light and the magnetron covers are well in place.
Clean the cavity thoroughly, clean also the lamp enclosure if this can be accessed. Carbon residue from food may be causing the arching.
If after cleaning the arching is still there, that means that the cavity is damaged. In that case better calling a technician.
A damaged microwave may loose insulation , and this may be very dangerous for health.
If you want to contact a technician, the best thing to do is ringing the phone number listed on the appliance owners manual.
Ginko.
on Feb 06, 2010 • Microwave Ovens
Microwave arching
faulty microwave module replace it
Its arching and humming
Once a microwave starts arching it is a real problem. They are coated with a special paint and if the paint gets scratched then arching gets worse and it can burn out the whole oven. See this page: http://www.microtechfactoryservice.com/
2helpful
2answers
Arching and sparking when run empty
microwave should never run empty. the reason is that the microwaves needs to heat something. more info : google - how microwaves heat food?
Started arching
This can be caused by grease in the oven especially on the paper like filter inside most of them. If it has burnt spots it may need to be replaced.
Microwave is not heating food and sounds like it is arching
Arching is often caused by a bad magnetron, the power diode must also be tested.
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
4helpful
Arching inside microwave
un plug it right away.
there are carbon deposit near the wave cover. the arching is coming from the magnetron to any exposed metal inside the unit or any carbon deposit since carbon is already conductive, it is sensing it as a metal.
remove and clean the interior of the microwave. polished and paint all exposed metal that you will find in the interior.
then test again the unit.
tnx 4 using fixya,
drcool
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
