JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
A
Anonymous Posted on Sep 05, 2005
Jvc gr-dv800us camcorder
Whenever I burn to dvd or video cd, video is not sharp. I use imagemixer to capture video and nero 6 to burn dvd. My pc is AMD K7, 120gb, 256mb ram, and xp. Do I just buy another program to capture video? Thanks in advance.
Anonymous
Level 3:
Master:
  • Master 473 Answers
  • Posted on Sep 05, 2005
Anonymous
Master
Level 3:
Master:
Answers
473
Questions
72
Helped
95498
Points
1373
I have the dv800. And I was not happy till I connected with firewire, used WinDV and then off to DVD with Ulead Moviefactory. Sadly, I can only share my success so you might follow along.
1helpful
How do i get moving images from my GR-D290 to my PC? I can watch them on my camcorder but would like to get them loaded to my PC so that I put them on a DVD. And so that I can record new events
Use Firewire cable connected to firewire port of Your computer. Even Windows movie maker can capture images from any DV camcorder. After capture it´s easy to burn DVD with any burning software. For more questions email me.
2answers
I HAVE JVC GR-DX307 AS - how to save the video on my laptop or how to save it on dvd
Hi and welcome to FixYa,
To save the video on a computer, a firewire connections must first be established from the JVC GR-DX307 AS to the appropriate firewire port of the laptop (assuming it has one or through a PCMCIA firewire adapter card if required). In the camera, the FireWire/DV port is located beneath the mode dial on the left side of the JVC GR-DX307’s body. To access the FireWire/DV port, the LCD monitor must be first opened.
Soon as that connection is established, you can use Windows Import Video (Vista) to capture / download the videos.
Alternately, the A / V port of the camera maybe used to connect to a DVD Recorder for direct, realtime copying & burning. For the disc to be playable in another machine, it must be finalized.
Good luck and thank yu for using FixYa.
Can't connect to computer
Hi, You need to first capture the video using Windows Movie Maker.
Then the movie maker will let you burn it to a DVD/ CD
JVC Camcorder GR-D33U
try this steps
  • first install the driver camed with your camcorder to your pc. this should recognize your computer after the installation.
  • use USB cable to connect your camcorder to your pc.
  • as far as i know jvc is using a software name ulead (because i also have a camcorder and its software is ulead)
  • Try to use Ulead Movie producer, Windows Movie maker or any other software that accepts uploading dv video.(i prefer to use ULEAD movie producer or any Ulead products its easy to use)
  • After uploading it from the ULEAD and editing, save it with any various types of videos you like. (in your case save it in DVD format so that it will easy for you to burn it.)
  • Use NERO after searching the save video file and Burn it in DVD type
I hope you understand my procedures and steps on how to transfer it. if you have further questions just contact me. hope that helps!
thank you for using fixya
CHARCOIS
JVC gr-d70 connection / uploading
wrong connection! you must use firewire to stream video and audio from your cam-make sure comp has connection-called 1394-on cam it's called dv and get proper cable and you will be fine-usb only for pics
5answers
JVC GR-D295US video recording downloads to PC
u will need the software form website latest verison ok jvc.com then driver download area for yourmodel save to hard drive then install then u can tranfer thx nick
VL-Z7E
YOU NEED TO PURCHASE A DEVISE CALLED CAPTURE CARD AND CAPTURE CABLE ONCE INSTALLED IN YOUR COMPUTER YOU NEED PROGRAMME LIKE PINNACLE STUDIO TO CAPTURE EDIT AND MAKE CD FOR MAKING DVD YOU NEED NERO 7 OR ABOVE
2answers
BURN HOME VIDEO TO DVD
Assuming that your camera is not equipped to interface directly with your PC, here are the steps to take to get your videos from VHS to DVD:
- Purchase a video capture device.
A cursory websearch garnered once for $50.00 here:
ADS Tech Video Xpress
http://www.pcmag.com/article2/0,1759,1902901,00.asp
- After setting the device up, use the bundled software to convert the video file into DVD format and then burn to disc, using your favorite burnig software. Be sure that it is burning in the VIDEO_TS/AUDIO_TS format and not just copying the .avi to the DVD.
If you would like for me to elaborate on anyt of these instructions, please don't hesitate to contact me directly at [email protected]. Good luck and, again, let me know if there's anything else I can do. I think you'll be just fine though as this process is fairly straightforward...just time-consuming.
2answers
JVC GR-DVF31 - How to transfer MiniDV to PC?
buy that wire, check ur camcorder if it has 6pin or 4pin for firewire then check ur pc if it has firewire card...if not you have to purchase the ieee1394card. install it then connect your camcorder to pc through firewire and that will be it.. u also need to have a software for video capturing and editing like adobe, roxio, pinnacle , etc...hope that helps.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
