Question about RCA HD52W59 HDTV Projection Television
Picture on screen is too big head of people are cut off it does not show complete picture
  • RCA Master
  • 736 Answers
Use your cable or satellite tv remote to adjust the aspect ratio. If you have cable there is a button on the remote called hd zoom and it has this symbol: #. On the satellite tv remotes it usually says format or aspect. You might even have to go into the cable box/satellite tv receiver menus to adjust the aspect ratio/picture format. Once you have done so you can fine tune the picture even further with the television remote's wide/format/aspect/zoom button. Also check and make sure your television is on the right input and that your cable box/satellite tv receiver is set at the right resolution for the television 1080p/1080i/720p.
Posted on Jul 12, 2011
6ya staff
SOURCE:
How can I make the image on tv screen smaller?
Press the Format button. It's directly below the power button. It has a symbol of a rectangle with a double-headed arrow inside.
Press it to cycle through the different picture shapes.
Sep 10, 2014 | Emerson LC320EM2 32" LCD HD Television
Why is the picture is to high or big and cuts off the heads of the people on my RCA HD52W59 rear projection HGTV
its setting the screen format . take the factory remote and by using the cursor left or right you can scan the size changes
May 23, 2014 | RCA HD52W56 52" Rear Projection HDTV
The picture is too big for the screen. how can i make the picture match my screen size?
Posting the model number would make a response more valid but you need to go through the main menu selection and check to see if you can alter screen resolution or geometry there.Most sets offer different views such as 'Panorama,' 'Full screen,' etc.
Nov 21, 2011 | Sanyo Televison & Video
Picture too big for screen; cutting off top of heads and bottom of screen
Go to the picture setup of your settings menu.
Somewhere in there are options for selecting picture size.
The options will be similar to: Normal, Wide, Zoom, Stretch
You have probably selected Zoom, try Normal.
May 18, 2011 | Hyundai Q321 32 in. LCD Television
The picture is too big for the screen...heads are cut off and guide is cut off on the top when changing channels
Change the aspect ration in the picture menu for a different apperture.
Hope that helps.
Jan 16, 2011 | RCA Televison & Video
Picture too large for screen
crop the picture edges using photoshop
Jun 17, 2010 | Insignia LCDTV26 26 in. Television
Picture too big.
HDTV's come with selections that will change the screens display, on the remote press the format button and you should be able to find a setting that you desire.
Sep 07, 2008 | Sony KDSR50XBR1 50" Projection HDTV
on your remote push the arrow key to the right or left side. this should change format and go into customer setup and turn of autoformat
Aug 31, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W17 Picture is cut off at the top of screen
is it a black area on the screen? or just cant see the heads anymore? either way its proabaly a setting on the remote such as zoom or ratio
Jun 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Cutting off part of the picture
check that the pic is not too big for the print mem if so try changing the port settings to spool or print direct
Mar 30, 2008 | HP Photosmart 3210 Printer
RCA HD52W59 HDTV Projection Television Logo
392 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
