Question about Fisher and Paykel DEGX1 Electric Dryer
I have a DEGX1 model, top load dryer. It was working fine, but when i went to start it recently, it sounded like it would start and then the beeping started. I checked the code sheet and it says it is Fault Code 7. Replace the motor control module or replace the motor. Could anything else cause this error?? Like it's very hot in the building that the dryer is located in?
    Top Expert:
  • Fisher and P... Master
  • 12,962 Answers
Hot wire the motor to see if it runs. If so, module is at fault.
Posted on Aug 31, 2017
Anonymous
SOURCE:
Anonymous
  • 83 Answers
SOURCE: Won't heat
Not sure how old your dryer is but earlier models had the element around the door.
As a rookie you would have to remove the rear cover, the drum, the belt around the drum and then you would sse the element held in place by clips on the inside of the front panel. The thermostat would placed not too far away. I have just purchase a new dryer (very recent model) and was told the element is located away from the door. I guess I won't know until I have a problem with mine.
As usual, heed the warnings about electrical appliances and the risk of electrical shock.
Always unplug the appliance from the power point as you can still get a stock on the neutral connection even if the swith on the power point is turned off. (tunrs of the active connection only).
Posted on Sep 14, 2008
Anonymous
SOURCE: Fisher and Paykel dryer not drying
I've had this problem for 3+ years. There are possibly multiple reasons why your dryer trips the reset switch. My dryer has a design issue with the lint trap, in that it allows lint to build up around what I assume is the heat sensor / thermal switch. It's simple, the temperature is detected as too high in the dryer and trips the switch which cuts power to the heating element. The reset switch access as mentioned in other posts requires either tipping the dryer back or removing the front panel, at least partially, to access the switch. After the reset switch is pushed, you'll need to check if there's lint built up that's causing the reset issue. First, find the reset switch.
To access the switch, there are 4 Phillips head screws that need to be removed. For the first 2, lift the dryer lid and you'll see two half-moon shaped rubber inserts at each of the front corners of the machine. The inserts can be pulled out with your fingers or use a screwdriver, gently. There is 1 screw under each insert that needs to be removed. Once those screws are out, you can put the lid down and lift the plastic top of the dryer that the lid normally rests on. It's attached on the back of the dryer so don't worry, it won't come off...it will lift just like the dryer lid. Be careful of the sharp sheet metal edges. Now there are 2 smaller screws, 1 at each front corner, that attach the sheet metal pieces. Remove each of those screws. To get the front off requires a bit of finesse. You'll see that the front sheet metal panel of the dryer has bends in it to attach it to the sides of the dryer. Gently pull at the top corners, one at a time, to separate the front panel from the rest of the dryer. You'll see that there are u-shaped orange or red plastic pieces inserted into the sheet metal sides that align with holes in the front panel to hold the skin of the dryer together...the front should just pull away from those u-shaped pieces. There is a wire with a clip attached to the bottom of the front panel, probably a ground wire...if it pulls off when you remove the front panel, just reattach it when you put everything back together. The front sheet metal is also integral to the front feet of the dryer, so tilt the top of the front panel toward you and lift. The front panel should pull away. When you put the front back on the dryer, do it feet first by aligning the plastic foot pieces, then align the u-shaped side pieces, then worry about the top corners wrapping back around so the front fits flush.
The reset switch is in front at the bottom right of center and is probably orange. Just push it and you'll hear it click. I would vacuum out the lower part of the dryer at the point, but it's probably not what's causing your problem. I've gotten to the point where I use a yard stick or vacuum extension to push the switch without completely removing the front panel. Then I don't have to detach / reattach the ground wire. You'll see after you do it 3 or 4 times!
Now check to see if lint build up is causing your thermal switch to trip. Pull out the lint trap and you'll see 1 Phillips head screw behind where the lint trap normally sits. Remove the screw, and you'll feel the circular plastic piece the lint trap sits in become loose...pull this round piece out of the dryer from the bottom. If there is a lot of lint behind this circular plastic piece, that's probably what's tripping the heat sensor. Vac it out. Gently feel around the circumference of where you removed the piece to see if the fine mesh lint screen has any holes (if it does, it may be blowing lint into your exhaust and eventually clog the vent to the outside). If the mesh is torn, I assume that larger circular piece needs to be replaced at some point in whole or part. From what I can see, the design of the lint filter and trap is ....****. The system allows lint to enter the area where the heat sensor sits.
The short term fix is to vac out the sensor area regularly and that will keep the switch from tripping, if that is your actual problem. I believe F&P is aware of this issue and will probably remedy it for you. I called them once when this issue originally happened and had to wait for a tech to come out do what I described above. I haven't called them since, but have seen other posts regarding a new part or parts that F&P will provide...hopefully free! Good luck!
Posted on Jan 10, 2009
Anonymous
SOURCE: Wont start. Extra dry light on and cool down light on.
Fault #3 Drum Stalled; unable to move.
  1. Check drum movement mechanisms: belt, motor and motor harness (if motor moves drum slightly, treat as fault #2)
  2. Replace the motor control module.
  3. Replace the motor.
Fault #2 Drum Gap Cannot be Located
  1. Ensure sensor module is correctly located and clipped in.
  2. Replace the lens on the sensor module.
  3. Replace the sensor module.
  4. Remove Top Deck and clean the sensing bumps on the outside of the drum end.
  5. Replace the drum.
Posted on May 15, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
Posted on May 29, 2009
Anonymous
SOURCE: DEGX1 dryer will not produce any heat. 5 years
I have the same model of dryer and the same problem and no experience in fixing any appliances. I took a few screws off the top and the front, opened the dryer by rotating it forward, and found a red button (a fuse or breaker?) close to what I figured would be the heat sink. Pressed the button, it clicked, and decided to put it all back together. First load worked fine, hopefully that was all it needed. Good luck and hope this is all you have to do too.
Posted on Jun 05, 2010
FPaykel Dryer model # DE05US2 is making a screeching LOUD sound ... still turns and dries just VERY VERY LOUD and high pitched squeeling
It could be bearing or guides in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My dryer is a top loading Fisher and Paykel and it has started squeaking.
It could be bearing or guide in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 21, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My top load dryer does not vent enought air to open vent door i have cleaned the filters and the fan
Check the exhaust tube, then go to to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Dryer drum does not close when starting the dryer
Aug 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I just got home from vacation and we went to use the Dryer but when you push the power button and the lights come on then you push start ... the unit does not start ... and the lights shift to as if the...
Try unplugging the unit for an hour and replugging it back in. If that doesn't work go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum may help you through your problem. Passed that while you were gone you could of had a power surge that burned the electronic out. If that's the case time your can replace some of the electronics.
Aug 04, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Getting sound when its working. reason for getting sound. Please help me..
Aug 02, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
100 people viewed this question
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
Dennis Boxerman
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
