Sony Cyber-shot  DSC-W200 Digital Camera Logo
Posted on Jul 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red light by the battery is blinking n doesnt turn on
Michael Vincent Cruz
Level 3:
Guru:
  • Master 868 Answers
  • Posted on Jul 13, 2011
Master
Level 3:
Guru:
Answers
868
Questions
Helped
273610
Points
2414
Hi bklynzrealis,
Seems that you battery needs charging, if you already did recharge the battery then the battery needs replacing if the red light blinks after charging.
I hope this help.
have a nice day,
mvincnetc
Can you help diagnose a tv with no picture or sound? just a baclklit and flashing red indicator light
The red light flashing is indicating the error.
depending on the make and model of the TV, the duration of the flash and number of flashes determines the error code.
1helpful
2answers
My headset doesnt turn on, when I plug the charger the red light starts blinking
Could be a combo of low battery and not yet being connected. Charge it overnight and check on it in the morning.
Check out the
Quickstart Guide
Mark
Motorola Support
3helpful
2answers
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
4helpful
3answers
Doesnt stat up and no light showing charge
Here's one way to determine the problem.
Take the battery out and try to boot on AC power only, if it boots turn it back off, reinsert the battery again and try to boot.
Sometimes you just have to take the battery out and plug it back in again, with others it is the battery and you have to leave then out until a replacement is bought.
If it still won't boot on AC only, remove and reinsert the memory, try to boot the computer and listen for any beeps.
Post back if you need further assistance.
Good luck.
4answers
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 • Cameras
The playstation 3 doesnt start
i think dat there's a big problem in ur ps3 so i think u'd better go n let someone who knows well in da ps3 like SONY support centerin ur country take care of it
or u may call or send e-mail to sony support using (www.playstation.com)
1helpful
2answers
Ds does not turn on at all
it is probably the battery because my sisters ds got wet and now it doesnt work you could go to nintendo.com and buy a battery only 15 dollars.
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
