Question about Sony BRAVIA KDL-46XBR8 46 in. LCD TV
My Sony TV KDL-46XBR8 begun showing lines in the middle of the screen about a week ago and now is showing a transparent block at each top corner. The TV is only two years old. Do you have any solutions for this issue?
  • 11,361 Answers
More likely to be the T-CON board.
Does it look like this in my albums?
http://s807.photobucket.com/albums/yy352/budm/SONY/Sony%20KDL-46WL140/
You will want to read or download the T-CON troubleshooting also.
T-CON: E40951307-TCON Troubleshooting 10-22-09_OPT
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jul 13, 2011
6ya staff
SOURCE:
I have a Sony KDL-46XBR8 Television and it intermittently has vertical lines on the display.
Below is a youtube video I guy did to address that problem. Sony provides a troubleshooting guide at this place, it may be similar to your Vizio model and help you.
http://techin.oureverydaylife.com/sony-lcd-tv-troubleshooting-vertical-lines-screen-35117.html
Nov 17, 2016 | Sony Televison & Video
Sony kdl-46xbr8, reset all settings, software update, nothing helped, all hdmi ports doing the same, the GUI does not have this issue so I know it's not the LCD screen, it happens only on hdmi
I had this happen and know what you are talking about. The tech guy talked me over the phone on how to fix it. He said the problem was a hang up issue, like the hdmi ports actually hang up the line like a phone call. He had me turn off the auto detect settings that talk to the other components and share info with each other. Then he had me reset the TV. It was a while ago so I may have reset the TV first then turned off the auto detect settings. Play around with it and I bet you will get it figured out.
Oct 10, 2012 | Televison & Video
Sony Bravia KDL-40w4100 vertical line issue
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
Jan 10, 2012 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
We have a Sony Bravia KDL-40V3000 flat screen television. About 6 months ago, the screen started displaying white, green and black vertical lines and dots. This continued for a few weeks and then the...
It's a connection inside the TV that's faulty. It could be as simple as reseating the ribbon cables that connect the control board to the glass display. Or it could be that the fault is on the board and needs to be replaced. The fact that the problem comes and goes should tell you it's fixable.
Apr 28, 2017 | Sony BRAVIA KDL-40V3000 Television
Model# kdl-40w4100 Serial # 8051767 2 years old Horizontal lines in 4.5 inch blocks at the top of the screen
I have the same tv model KDL-40W4100 and around the same age. At the moment I have 16 of
these horizontal lines over the entire screen and they seem to be grouped into 2 lines per row. They are also around 4 inches and two pixel rows high. I have been looking over the Internet for months and found nothing to troubleshooting this issues. In the last few weeks more and more of these groups of lines have been showing up and now i am up to 16 of them and it is becoming unwatchable. Any help from anyone would be greatly appreciated. I also attached a picture to describe it better. Thanks!
Nov 06, 2010 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Sony Bravia 42" Horizontal Lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 19, 2017 | Sony Bravia KDL-42V4100 42 in. LCD TV
Sony Bravia KDL 40S20L1
You should have a 1 year warranty from Sony. Call them before it expires. This is probably a LCD panel issue.
Oct 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Lines in the middle of screen
Fixed.  The problem was the B board (digital signal processor). Bring lots of money.
Dec 19, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-46XBR8 46 in. LCD TV Logo
883 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
