I'm not sure if you can repair it, but you can cover it.
Check out handle bar, bumper bar and bassinet/
seat frame covers for your bugaboo stroller foam at
www.bbsprouts.com
The stroller handles are not reversible and go to www.pegperego.com to find a manual to print.You can also call perego at 1800-671-1701 to order the replacement cushion.
Stand behind the folded stroller, ensuring the handle is on the top of the stroller.
Bend down and place your hands on the handle bar, DONT lift the pram, make sure it stays on the floor.
Push the white button on the inside of the left hand side of the handle bar.
Pull both triggers (located inside of the handle bar) toward you and lift the handle up.
Stand up-right, and place your foot onto the bottom of the two axles which you can see in front of you (make sure that you have your foot on the axle which connects the two small swivel wheels).
Whilst you are standing, with your hands on the handle bar and your foot on the axle, push the axle out with your foot away from you and slightly upwards. This should open the chassis up-right. Please note that the chassis will appear to be unstable and move, this will stop the minute that you click on your carseat/carrycot or seat unit.
I hope this helps.
if you go to peg perego.com then click on the online peg perego store. then click on accesories. they have a bunch of them for about 80 dollars. Im going through the same thing. also if you google peg perego p3 5086 manual a website pops up and has a manual you can print and save
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
On Ebay, if you type in Bugaboo on the search field, there is an item called Stroll-air that covers the handle bar. I think it's made of neoprene (like wetsuits) or something that looks like it.
