If the pictures are on a memory card then remove the memory card from the phone and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be the fastest. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
If the pictures are not on a memory card, then connect the phone to the computer using the appropriate USB cord. Your computer will see the phone as an external storage device, and you can proceed as detailed in the previous paragraph.
Connect a USB cable from your phone to the computer. If you can't find a cable, insert a USB dongle to your computer and transfer your file via Bluetooth.
Just turn on your bluetooth on your phone first then turn on the bluetooth on your laptop if there is.
Then you can transfer your pictures via bluetooth, but if your PC has no bluetooth, you can use a USB cable from your phone then connect to your PC, then you will have the option to send data from your Phone to you PC.
the easiest way would be to text the pix to an email address, the other way if your phone is capable buy a data cable and software than transfer that way
you have a few options for that
1. you can send a picture message to your email address
2. if your computer has bluetooth capability you can connect to the computer using that or you can buy a USB cable for your phone. Once you are connected toyour computer you can drag and drop the files between the phone and computer. Just go to my computer and the phone will show up as a removeable drive.
