Roper RS22AQXKQ Side by Side Refrigerator Logo
Posted on Jul 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Roper Whirlpool side by side - freezer has frost & some ice but fridge side is not cooling like it used to ... should we try defrosting it and if so how long do we unplug or what is the best way to do it & afterwards to we not put anything back in until 24 hrs later ?
Anonymous
Level 3:
  • Master 1,998 Answers
  • Posted on Nov 24, 2011
Anonymous
Master
Level 3:
Answers
1998
Questions
0
Helped
620349
Points
5972
If you were to take everything out of the inside of the freezer and look at the rear wall of the inside of the freezer you will notice there are screws on this panel so that this panel can be removed. Once you removed this panel this would give you access to the evaporator coil. If you look above the coil you will see the culprit that makes them awesome noises you enjoy so much. If you see any ice build up anywere in this area you would defrost it with a hair dryer. This issue is called a defrost problem that your unit is experiencing. This is due to one or more of three basic parts. Two of those parts are located right in the area where you have accessed the evaporator coil. You would need a multimeter and be able to perform an ohms test on each of these next two parts mentioned to diagnose which part or if both had a fault. The first part is called the defrost thermostat which is a small round sensor that is clipped onto one of the copper lines near the top of the evaporator coil. Here is a link to click that is the entire schematic for your machine if the last numbers after the q that you posted were 03 there are three models an 04 as well as an 00. The 03 has 3 more parts listed then the others. http://www.searspartsdirect.com/partsdirect/part-model/Roper-Parts/Refrigerator-Parts/Model-RS22AQXKQ03/0893/0165000?searchedModel=RS22AQXKQ&blt=11
you would then go into the unit section and click that as well your defrost thermostat is part number 35 and the defrost heater is part number 33 do the testing on these parts and if you find no fault message me back and I will explain more on the defrost timer or adaptive control due to the look up site just went down for maintenance. If you have any questions message me those back as well. Thank you
Rick
  • Anonymous Nov 24, 2011
    By unplugging the unit it does defrost the unit and get rid of the ice, but this does not correct the problem from iceing up which it would and you would have the same issue within 3-4 weeks afterwards. The defrost thermostat when conducting an ohms test should read at around.50 ohms or higher. The defrost heater usually reads above 20 ohms. Most of the service calls I go to to repair a refrigerator that has a defrost issue about 80 percent of the time the issue is due to the thermostat. I await your reply if you have any questions. Please also remember when our chat has FULLY concluded to rate how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future.
    Thank you again
    Rick
1helpful
Whirlpool fridge freezer
The fridge side is cooled by the freezer side. Try unplugging power, open freezer door and let thaw out/defrost.
Whirlpool ffw400wh cools nicely for 3 days then form ice on the freezer & does not cool at the fridge compartment
Sounds like your defrost timer is not functioning , it will need to be replaced. Some times the frost free fan can also cause this but I think it will be the defrost timer.
Located under the fridge usually on one of the rear corners.
Pit has like I white round dial on it .
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
MY WHIRLPOOL ED5VHGXMB11 DOES NOT DEFROST.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
4helpful
3answers
Maytag msd2641kew fridge side is not cooling its warm . freezer is still cold notice some of the ice look like it was starting to melt a litte. turned freezer up acouple of hours ago stuff is staying...
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
A layer of ice keeps forming in the bottom of the freezer. can chip it out and a new layer will start forming by the next day. also has a lot of frost as well. thuoght was the seal and have attempted to...
Top of Form
Freezer Freezes, but Ice/frost collects inside however the refrigerator side doesn't get cool enough! is this something I can easily fix?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Our freezer and fridge or not keeping cold enough
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor or back of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
1helpful
2answers
Whirlpool double door fridge side is not cooling,
sounds like a defrost problem. check to see if there is any frost buildup in the back wall of the freezer. if so, it is not defrosting like it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
Top Roper Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
