The first thing to check is the air filter. Make sure you replace or clean it well. The second thing, if that doesn't fix it, is your fuel. If it's gas, change it. If it's propane, make sure it's got correct pressure., possible bad pressure regulator.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
SOURCE: COLEMAN powermate 5000 generator w/a Subaru engine
Check the vent in the fuel cap to make sure its free to breath. It could be creating a vaccume in there and starveing for fuel. Maybe run it with the gas cap off and see if the problem gos away.
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
SOURCE: Need to replace fuel shut-off valve
well..the whole valve has a place where u can place a 12 or 13 size spanner...and then just twist it..
don't hesitate to write to me for further information:
[email protected]
