Just bought an LG Infinia 47LW5600 and hooked up my ps3 via hdmi. i then put in a 3d bluray and a message apears saying this dis has recogonized that your player and or displaydoes not support 3d playback. alsp ps3 is running the latest update and i watched a 3d trailer from vudu prior to hooking up ps3.
Assuming you have a 3D TV, AND either a service offering 3D programming OR a 3D BluRay player AND a 3D BluRay disc, AND it is properly connected via a suitable HDMI cable and port, AND the required 3D glasses... you turn on 3D according to the specific instructions of your TV!
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Are you sure that your PS3 is connected to your TV with a HDMI cable? Make sure that the PS3 is connected to the TV via a HDMI 1.3 cord and recheck your settings on the XMB and on the game itself.
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best,
John
if this is the first time you've hooked it up via HDMI then you have to go back to the old cables first. Hook those up to the old TV or the new one, then go to settings and switch to HDMI. It will give you 30 seconds to change the plugs again so you can view the HDMI. Then select ok. Hope this helps
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
