What size of drill to use?
SOURCE: chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
SOURCE: how the cordless drill works in drill mode,
the basic operation for the drill working in the drill only mode is you tighten the clutch up which puts more pressure on the spring not allowing the clutch to ratchet like it would in another position therefore bypassing the clutch completely. Give me the brand and model number and I will try and find a parts explosion for you.
SOURCE: How do you fix drill bit in drill.I have followed
take screw out from inside chuck and remove chuck then put a new one on.
