Washing Machines Logo
Posted on Jul 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I replace the presure switch? - Whirlpool LSQ8543J
Anonymous
Level 2:
  • Expert 179 Answers
  • Posted on Jul 15, 2011
Anonymous
Expert
Level 2:
Answers
179
Questions
0
Helped
49468
Points
446
Take the two screws in the back of the control panel. pull the control panel foward then up. pull the knob off the pressure switch. pull the tab on the pressure switch and turn the pressure switch pull the hose off.
1helpful
2004 hyundai santa fe power steering pump is squealing
sound like you have lost presure switch that is supposed to relive presure when presure is high or the belt is too tight putting presure on the bearing causing over heat or oil cooler restricted and not coolling the oil
My oil pressure light come on all the time how can i fix it
check on your oil presure switch wire and also have your oil presure measured . could be ur switch is faulty if presure is low change oil pump
My 2 group astoria over steams from top of boiler.it warms up then in about half hr steam shoots out at the preasure valve doicky do i need a new one of those thanks greg
The pressure releive valve is pre-factory set to open if the pressure in boiler reach between 1.6 to 1.8 bars.
So either you have the presure switch (presostat) not working normal which supose to switch off the electrical element at 1.2 to 1.3 bars.
So look at the presure gauge at which presure the presure releive valve open and releive the steam out from boiler if it shown more than 1.5 bar the you need to check the presure switch since it does not switch off the heating element.
If the presure releive valve open below 1.5 bar then you need to replace the releive valve.
Good Luck
Air switch open error code, can't get ignition.
hI blow dow tube s of presure switch might be blocked , jump out pressure switch see if it lights if so new presure switch
1helpful
2answers
2answers
Bad control board?
This is a good one! I would check for a blocked vent or intake pipe first. Also check to make sure the condensate lines are free of moisture or debris. What is the code for three blinks?
3answers
Air conditioner will not turn on
has the charge been tested< these suffer from leaks, have the system leak tested and then repair and recharge.
Red light
if the oil light is staying on it could be one of many things ,it could be a very cheap oil presure switch or something very expensive if it is an oil pump failure.start with doing an oil presure test . presure should be 14 to 57psi(2.0to5.0bar)@3000rpm. oil at 60c
if all is ok check cable going to switch for breaks or touching frame and shorting out,if thats all ok next change oil presure switch . if the test do not produce the results to spec then the right hand side off engine will need be striped down to replace the oil pump and inspect the internal engine componants for oil starvation damege which could result in a complete engine overhaul. i would not be using the bike until repaired. engine seizer can result in an accident.
Lack of oil presure
Hi ...... First thing to try is replace oil pressure switch if that doesn't work come back. Defective batch of these were fitted.
I have a bosch 24cdi rsf combination boiler reaching 3 bar pressure and blowing off through release valve. any suggestions.
if this occurs when the unit is in use for only hot water, there will be an internal leak in the secobndary heat exchanger, you will have to replace it. check first that the charging link has been removed when testing to ensure it is not passing.
if it happens when the heating is switched on then check the presure in the expansion vessel ( dump all presure from system and use a car foot pump with a gauge there should be 1 bar presure) that is the big red thing behind the pump, if water comes out of the test valve on the front of it when you try to test it or it wont hold the presure you will have to replace it (a nasty job you have to strip half the boiler) if you can pump it up make sure you release the presure in the system as you pump it or you will get a false reading
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
