Cell Phones Logo
Posted on Jul 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
Anonymous
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Jul 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
2616
Points
83
You could connect using your bluetooth, just turn on your bluetooth and connect.
Anonymous
Level 2:
Scholar:
  • Expert 30 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
30
Questions
0
Helped
11668
Points
104
If your phone doesn't have a data cable to connect to your PC, you can connect it via Blue tooth.
As long as your Mobile & your PC is Blue tooth as well.
If they are both blue tooth.
  • Switch on Blue tooth on your PC
  • Switch on Blue tooth on your Mobile, go to menu, Connectivity, Blue tooth, turn on Blue tooth
search for More Devices, once you do a search it will have found your Computer Blue tooth, select the computer it has found, it will ask you for a pass code, enter any pass code you like for eg. 23456 once you have entered this your computer will ask for a pass code as well, enter the same number, and this will pair your Mobile to your PC.
I hope this helps you.
If so please leave a vote or comment.
Have a Great Day
MobileJB
1 Related Answer
Anonymous
  • Posted on Nov 28, 2009
SOURCE: HOW CAN I CONNECT MY NOKIA 1209 TO COMPUTER WITH DATA CABLE.
Yes you can using "mobifx"
I have mobile phone model number 5130 express music i want to update softaware but its written that i have lost some ovi files from it now i m thinking to have a flashing to my mobile what charge will...
Hi
It's possible to flash your mobile in Home,
For Flashing the Nokia phone u just install the supportingsoftware Nemesis1.4 to internet. Install in your PC and connect your mobilethrough the data cable, You see the 3-4 option will appear in your mobilescreen please select PC-Suite option, Now open the nemesis click thedevice info after detecting the info in your mobile click the Flash Option andselect the Normal Mode, then click the after flash option and click the Restore-Full Factory option and click the upload, after few min your mobile restartand it's On Factory Default Setting pleas input he Date and time and selectyour time zone.....
Download the Nemesis1.4:
I FORGOT SECURITY CODE OF MY NOKIA 1209,IMEI 356927/03/226938/7
Hi lebasa.....
You can unlock by 2 methods 1)you can get master code from
http://www.unlock-zone.com/
or
http://www.nokialockcode.com/mastercode.php
and
superunlockcodes.com/unlocking-services/rs12wp6/ (You have to pay for these)
2)You can flash(format) your handset to reset code 12345
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you have a nice day....:)
How do i transfer contacts from nokia e51 to htc p3450 using laptop as the cd of htc dont work
1.Install your nokia pc suite .
2.Then connect your mobile with data cable.
3.Open your pc suite the click Synchronize and save the contacts to pc.
4.Install HTC pc suite .
5. Now import your contacts to htc using data cable by HTC pc suite.
1helpful
2answers
Well i have nokia 2626 mobile can i connect it to laptop and use as a internet through data cable.i have a prepaid airtel mobile connection.i have install pc suite on my laptop
You cannot connect your NOKIA 2626 to laptop to browse through internet.In this mobile you dont have this option.
Thank You
2helpful
Want to operate Hand phone in computer
Nokia 1100 is non-compatible with PC, you require Nokia 3300 and above. you require data cable for your mobile and Nokia pc suite for driver. First install PC suite then connect mobile to pc through data cable. connect mobile only when asked by pc suite.
Aug 15, 2009 • Nokia 1100
7helpful
Software for connecting through data cable to pc
Hi Friend,
For connecting the PC and the Mobile through the Data cable you have to use the Nokia PC suite which has to be installed in your PC.
You can download the PC suite form the below link as follows,
http://www.nokia.com.sg/get-support-and-software/download-software/nokia-pc-suites/compatibility-and-download
1.Install the PC suite to the PC
2.Access the mobile from the PC through the Data cable
3.Now can transfer the datas through the data cable from PC to Mobile and from Mobile to PC
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Cant get connection from pc ..to mobile (ok from mobile to pc)
well the best way to connect your mobile with computer is through data cable.. you should have nokia N73 data cable (DKU-2) and download nokia pc suit from nokia website..
Usb
You need to buy a cable like this:
3b2f2e5.jpg http://www.sourcingmap.com/usb-data-power-cable-for-nokia-n95-p-10846.html
And you need to download Nokia PC Suite v6.85.14.1 to connect your phone to your PC. Not absolutely necessary but it's the best.
4answers
W880 usb connectivity
U need to install motorola phone tool software(Comes along with mobile)  in ur computer after install that software u will get an  icon on desktop of motorola phone tool then when u will plug in data cable with mobile and computer u will get a picture  of ur mobile on ur computer after open Motorola phone tool icon from ur desktop
Gizmo1
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
