SOURCE: hp psc 1315 driver
Heres the link , hope it helps , just click
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=374568&lc=en&cc=us&dlc=en&submit.y=5&submit.x=3&lang=en&cc=us
temu,
Click here to get free driver and software from HP
Thanks
Iqbal
SOURCE: hp psc 1315 paper jam
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
SOURCE: scan from hp psc 1315 to Mac OSX
first remove the printers folder,then the drivers manually one by one from the receipts folder,then remove the hp software. Deselect the hp in the printer preferences and then install the hp software again. And then it should work. Check in the printer preferences for your printer, If the hp fax is in there. Remove it and select the printer and thats it.
1.printers folder is located on the hard drive-library-printers
2.reiceipts folder is located same-library-reiceipts
3.Download the software from hp website.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
