Question about Dewalt 12V XRP Battery Pack
Holding battery charge on 12v DeWalt batteries
I have both 12v and 18v Dewalt drills. The 18V is outstanding, but the 12V will not hold a charge on either battery. I can charge it up and it works fine for a while, but even on a full charge, the next morning it is down...both batteries act the same....the 18v drill holds the charge just fine.
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Posted on Feb 24, 2010
    Scholar:
  • 62 Answers
Time to replace the batteries. Some batteries will not last very long. My original ni-cads on a Ryobi lasted only 1yr, and the replacement ones are 2yrs old and are still OK. You might be able to check the manufacturing date on your original batteries and that will give you an idea of how long they sat on the shelf before you started using them. Rechargable batteries have limited shelf life.
Posted on Aug 27, 2008
That is because of the battery type.  The batteries are nicd Nickel Cadmium and after 24 hours lose a good percentage of their charge.  The Dewalt batteries should be left on the charger, if you read the manual you will discover this is what Dewalt recommends.  It not only does not hurt the batteries it allows the charger to put the batteries through maintenance cycles.
Posted on Dec 30, 2008
I have read somewhere that running the battery down, and then shorting the battery, putting a wire acrooss +/- termanals. This interrups the recharge memory within the battery.
If this does not work the a cell my be gone and you can get these repaired
Posted on May 19, 2009
6ya staff
SOURCE:
Dewalt 30 Minute Fast Charger does it work in uk 230v
Some battery can not be charged by fast charger, because this can damage the battery. You can think to replace it to a new charger, a 7.2V 9.6V 12V 14.4V 18V NI-CD NI-MH BATTERY charger for Dewalt
Jun 22, 2014 | Drills
Will dc24sa charg a 14.4 battery
I have a 12v an 18v Dewalt I can charge them both from the same charger
Mar 07, 2014 | Makita 6932FDWDE 14.4V Impact Driver
I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery. I tried charging them and back to back they all start off charging fine then charging light speeds up as to suggest their all bad. ...
May read instructions and see if charger is compatible of charging the two types of batteries you are charging ,,,,I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery
Sep 27, 2017 | Drills
Need to know what terminals to conncect a 12v charging system to a Dewalt 18v battery in order to recharge it. I know it is a three prong system and I am assuming that the small center ground is used for...
I do not recommend connecting anything but the factor charger to the battery. No 12v will not not charge an 18v battery.
They can BLOW UP if you apply too much current.
The correct charger can be found cheap. Look on craigs list under tools.
Good Luck
Feb 01, 2011 | Dewalt Drills
I have a Ryobi 18v drill with battery 130429002 that will not hold a charge. Expensive battery with very little use. Can you help?
If both batteries won't hold a charge the problem may be the charger (not providing a full charge). If one battery is OK and one not holding a charge, the problem is probably a defect with the battery. I know there expensive, (I recently had to replace one for DeWalt).
Aug 18, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Faulty devolt batterie
Try placing the battery in a freezer for six hours before trying to charge the battery and if this doesn't work find a friend with a working charger and make sure using that method that you don't just have a bad charger.
Jul 24, 2010 | Dewalt 12V XRP Battery Pack
My dewalt hammer drill with lithium battery drains battery instantly and is 6 months old
Even though it is only 6 months old, the battery could be faulty here as it seems it is not holding any charge.
Jan 31, 2010 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Dewalt 18v nicd battery not holding any charge! what can i do
if it is under warranty ,take it back .if it isnot then bite the bullet and buy a new battery ----try TOOLKING
Nov 02, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt 12V XRP Battery Pack  Logo
1,903 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
