Question about Frigidaire Washing Machines
Load size in Lbs. What is the maximum load my washer can handle.? Model #: GLTF2940ESO, Serial # XC53923838 purchased on Nov 9, 2005.
  • Frigidaire Master
  • 1,902 Answers
Hello & Welcome to FixYa
Please check these dimensions for your washer:
  • Width: 27"
  • Height: 36"
  • Depth: 27-3/4"
  • Approx. Product Weight (Lbs.): 204/217
  • Approx. Shipping Weight (Lbs.): 217
Please get back to me if you have any other questions.
Kevin
Posted on Jul 16, 2011
6ya staff
SOURCE:
What is maximum wheel size that can be used on merits challenger scooter
Only the stock size.
Merits Challenger Three and Four Wheeled Scooters - Independent ...
ilcaustralia.org.au/products/5611
Nov 30, 2016 - A rear wheel drive scooter with rear suspension, suitable for outdoor use. It is available with three or four wheels. Closed loop handles allow ...
Merits Parts - All Mobility Brands - Mobility Scooter and Power Chair ...
www.monsterscooterparts.com/mobility/mobility-brands/mehepr Merits Atlantis (P710/P7101/P7102) Power Chair Parts. ... Monster Scooter Parts carries Merits parts for all models, including scooter and power chair replacement battery chargers and battery packs. ... As an authorized Merits parts dealer, Monster Scooter Parts can help you find just the ...
Merits Health Products - scooter, power wheelchair, manual ...
www.merits.com.tw/ Merits is the professional manufacturer of health products. We specialize in scooter, wheelchair, home care bed, accessibility, patient aids and other home ...
Merits Challenger 4 Wheeled Scooter - Assistive Technology Australia
https://at-aust.org/items/6176 Nov 9, 2016 - Merits Challenger 4 Wheeled Scooter - UNAVAIL (Deleted). Learn More. Approximate Price: $4350. No supplier. (0 suppliers). For information ...
[PDF]Merits Pioneer 3 and 4 Owner's Manual.pdf - Scootaround
https://www.scootaround.com/.../merits/Merits%20Pioneer%203%20and%204%20Ow... Congratulations on the purchase of your new Pioneer 3 or 4 power scooter. We at ... tiller assembly, battery charger, and owner's manual. Contact ... Wheel Size.
maximum wheel size that can be used on merits challenger scooter Google...
Apr 05, 2017 | Health & Beauty
Is there a way to add a trailer towing package to this vehicle as I need to hall 4400 lbs?
No, the car is rated to tow a maximum of 1000 lbs unbraked, so you are way off.
You will need a heavier and more powerful vehicle, something like a Dodge Durango. Don't forget to factor in the weight of passengers and any other luggage.
Apr 17, 2015 | 2002 Chevrolet Impala
What is the drum size of the washer?
Hello Friend, that's a great question!
In order to provide you the correct drum size of your Frigidaire washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front as you open the door if you have a front load washer. If you own a top load washer, you may find the serial tag inside the lid, on the right side. Thank you and I look forward to your response.
Jul 24, 2014 | Frigidaire FWSB5700DS Top Load Washer
Frigidare (GLTF2940ESO) front load washer
Hi , I would like to know how to soak my whites. When it is on a full cycle Thank you
Dec 11, 2012 | Frigidaire ATF6000ES Front Load Washer
How much air pressure to put in shocks with 2 riders
2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
Aug 30, 2011 | 2006 Harley Davidson FLHR Road king
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Broken door handle on washing machine
You can purchase any of the parts individually for the door handle.
If you go on line and enter Ariston door handle in search box, you shuold be able to locate the part/s you require.
Good luck.
Jan 06, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
FI Code on Sears Oasis Washer
Called the recall dept. for Sears. Have an appointment set up for two weeks.Gave them my serial number and model number. The said if the parts show up prior to the two week time frame...call them and we could re-schedule the appointment.
Aug 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
218 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
