Whirlpool (Kenmore) 'F06' states 'tachometer failure, no motor movement detected'.
Sorry but this requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
John C
John C
wow i like a customer who has done their homework :) based on all you have checked,if i were in the home, as the technician would recommend to you to have the drive motor replaced since the biult in tachometer isn't telling the mcu what rpm's it has spun at
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes. The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Hi There I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Check
wire harness connections between the Drive Motor/Tachometer
and the Motor Control Unit (MCU), and between the MCU
and the Central Control Unit (CCU)
Check
the Drive Motor
Check
the MCU
Check
the Wire Harness
Thank you for writing to fix ya. Best regards Richard
whirlpool awt 2481
color coding of electrical timer of whirlpool AWT 550
