Kitchen Ranges Logo
Posted on Jul 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove front panel on Maytag MAV7200 AWW - Washer?
Arjun Komath
Level 3:
  • Master 1,170 Answers
  • Posted on Jul 16, 2011
Arjun Komath
Master
Level 3:
Answers
1170
Questions
8
Helped
439650
Points
3355
Have a look at this link. You can get all informations about your washer/
http://www.appliance-repair-it.com/Maytag-washer.html
Thanks
1helpful
How to remove top of Maytag lavender 3600 aww
Remove 2 screws at bottom of front panel. Lift panel from the bottom outward. Panel will drop down and out. Remove two screws under top to remove top
1helpful
Makes screaming noise while washing. MAV7200. Belt or Bearing? Fixable by DIY?
MY MAYTAG WASHER IS MAKING A NOSIE WHILE WASHING A GRINDING NOISE DON'T KNOW IF IT THE BELT OR BEARING? WHAT DO I NEED TO DO?
Not cycling, draining or spining
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
6helpful
Have a maytag model PAV2300 Aww it grinds i have
gringing noise is never a good sign check the main bearing these are notorious for having bearings go and if it is bearing find a new machine its not worth fixing it is costs more then the machine is worth to replace
2answers
Re Your solution for my washer
its the spin brake making noise at the end of spin. once it gets humid out it will start all over again. its very comm. with this unit.
1helpful
Washer make a loud squeak when the spinning stops
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
This is a very com. prob. with this unit. its is expensive to fix and will come right back when humid out best thing to do is just put up with it.
1helpful
Loud noise -- water pump??
Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
Top Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Kitchen Range Expert? Answer questions, earn points and help others
