Machine started to shake bad during spin when moved to different location. noticed smoothed pins about 1/4" dia. 11/2" long came out do this need to be in. they dont show up on parts lists or diagram. whats proper location for these pins.
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
That is what these are bad for.... they are very hard to control especially if you are on a second floor or above a basement or something.... thats why i personally dislike them...
Check the Vibration damper rods to be sure that... 1. They are there and mount is solid. 2. If they are broken in 1/2. 3. The plastic knuckle mounts are not missing/broken. 4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
hi all you poor owners of this heap of junk, i have one too with the same problems, the shaking and moving around the bathroom was stopped by welding a 1/2 inch long piece of 1 &1/2 inch dia pipe to a 2 inch square flat plate of steel then putting double sided sticky tape beetween the plate and the floor
where you want the front rubber legs to sit, this stops it from running around the floor but it still needs to adjusted to have the
same on the front two legs to stop the shaking.by leaning the machine back a bit also helps to stop it leaking so bad while filling, it is only from the condersation from the hot water going in and the poor design of the soap drawer not allowing the water to run back into the washer which can be fixed by cutting the lip off
the bottom wher the drawer slides in then running a bead of silcone in the crack between the front cover and the inside piece
then another one on the front edge to run the water back into the washer. hpoe this helps. bryan.
