When
you boot up to the log in screen type in administrator as user to log
in if you cant log in during
the boot up process you will see on the screen for a short amount of time press
a certain key to enter set up press and
hold that key during the boot up process to enter BIOS scroll down to set user
password or supervisor password you can change or remove your password from
there also The
most common way that we know on how to reset or clear the BIOS password is to
physically remove the power from the computer by disconnecting the power plug
and then removing the Cmos battery for 30 minutes from the motherboard. Another
way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2
methods mentioned works because most motherboards use a battery to sustain the
BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the
battery power, the BIOS/CMOS settings will be erased. Hope this helps
Download the
HDD Unlock Wizard HDD Unlock Wizard v4.2 http://www.filebuzz.com/publisher/download.php?id=98078
HDD Unlock Wizard is a window based utility.
It works as a new life for your locked hard disks, as it is competent to unlock almost all hard disks of major brands available in market.
Its proprietary unlocking algorithms can remove any unknown HDD password and you do not required to give any hint of password as it is not working as a normal password cracker tool.
Removal of a HDD password is a slow process and total time required to remove HDD password is depending on the size of the hard disk and type of hard disk.
A small 2.5" notebook hard disk takes more time as compared to normal Desktop hard disk.
Presently it supports IDE and SATA hard disks.
hope this helps
also you might try
http://download.cnet.com/siw-portable/3000-2094_4-75449686.html
Software Inventory: Operating System, Installed Software and Hotfixes, Processes, Services, Users, Open Files, System Uptime, Installed Codecs, Software Licenses (Product Keys / Serial Numbers / CD Key), Passwords Recovery.
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
hope this helps
