Then you will need to flush the boilers out and rinse, its easy, just takes alot of time. First turn the water supply and the machine off and let cool, then back off the screw in the knob a few turns and pull off knob. Then remove the screws holding the front panel to frame. There's about 5 of them. Note the valves under the boilers with the red or black handles. They are usually in the middle. Use this valve to remove the water in the boiler, then fill boiler and rinse about 3 times each. Then reassemble and you should be good to go.
