Question about Tektronix Phaser 740P Laser Printer
I have a transfer kit error #33 I purchased a new transfer kit and installed it. i cant find the option to reset the copy count in the front panel. I am still getting the error with the new transfer kit HELP!
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 125 Answers
SOURCE: reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life
Posted on Jan 10, 2009
Anonymous
SOURCE: hp 4650 n - New Fuser Kit
Under the menu>Configure Device>Resets>Reset Supplies>New Fuser Kit
Posted on May 05, 2009
comercial990
  • 75 Answers
SOURCE: getting transfer kit error
I can send you a new transfer kit for 150 € + shipping cost.
comercial@ofiexpertos.com
Posted on Dec 17, 2010
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
80 scheduled maintenance will not print
There is a maintenance kit you need to get and install. Then you'll have to go into maintenance mode and reset the maintenance count. I don't remember the button sequence, but if there is a printere repair shop in your city, most likely one of their techs will tell you how to reset the count. But you really should install the kit first. It consists of feed rollers, charge and transfer rollers, and fuser. It's not difficult to install and the kit can be purchased with a refurbished fuser from many vendors at reasonable prices.
Mar 05, 2011 | Lexmark Optra T614 Laser Printer
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
How to fix transfer belt error in my samsung CLX3160fn
3. Select Tech Menu
4. Select DataSetup
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
How to reset PC kit e332n
To reset the PC page count, while the printer is on, open front cover then press the cancel button.
NOTE: The photoconductor page count should be reset only when a brand-new photoconductor kit is installed. Resetting the page count without replacing the photoconductor kit could cause the photoconductor to operate beyond its intended life and thus create print quality issues.
Oct 01, 2010 | Lexmark E332n Laser Printer
The printer doesn't recognise a new transfer kit
To reset the transfer unit count, do the following:
  1. Press the green tick to enter the MENUS.
  2. Press the down arrow to highlight CONFIGURE DEVICE.
  3. Press green tick to select CONFIGURE DEVICE.
  4. Press down arrow to highlight RESETS.
  5. Press green tick to select RESETS.
  6. Press down arrow to highlight RESET SUPPLIES.
  7. Press green tick to select RESET SUPPLIES.
  8. Press down arrow to highlight NEW TRANSFER KIT.
  9. Press green tick to select NEW TRANSFER KIT.
  10. Press down arrow to highlight YES.
  11. Press green tick to reset the transfer unit count.
Jun 21, 2010 | HP LaserJet 4650n Printer
I want to reset counters for fuser and transfer unit. Mike
Hi schoeller:
Hope this helps.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
1. Press MENU to enter the MENUS.
2. Press down arrow to highlight Configure Device.
3. Press check to select Configure Device.
5. Press check arrow to select RESETS.
7. Press check to select RESET SUPPLIES.
9. Press check to select NEW TRANSFER KIT.
11. Press check to select YES.
To calibrate the printer, do the following:
4. Press down arrow to highlight PRINT QUALITY.
5. Press check to select PRINT QUALITY.
6. Press down arrow to highlight CALIBRATE NOW.
7. Press check to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
To reset the fuser count
5. Press check to select RESETS.
8. Press down arrow to highlight NEW FUSER KIT.
9. Press check to select NEW FUSER KIT.
The fuser count is reset and the printer is ready to use.
Hope this helps.
Jul 10, 2009 | HP LaserJet 3700n Printer
Installing a Transfer Kit
i got this info from www.partshere.com site - they have most service notes for hp printer and sell most hp parts, including maintenance kits. I hope info. bellow is helpfu.
Replace the transfer unit when the printer control panel displays REPLACE TRANSFER
KIT
. The image transfer kit contains a replacement transfer unit for this printer.
WARNING! Remove any jewelry or any other metal items from your body to avoid electric shock.
1. Lift the front door handle and pull down the front door.
2. Grasp the right blue handle. Press and hold down the blue button. Slightly lift the right
side of the transfer unit.
3. Grasp the left blue handle and lift to remove the transfer unit from the printer.
4. Using handles, remove the new transfer unit from the bag. Use the blue handles on both
sides to hold the transfer unit.
5. Place the new transfer unit on a flat surface. Remove the orange shipping locks.
6. Guide the left side of the transfer unit into the front door of the printer. Insert the two
pegs on the left side into the holes, and then lower the right side into the door.
7. Make sure that the blue button on the right blue handle has released (popped up). If the
button has not released, grasp the right blue handle and pull the transfer unit toward you.
8. Firmly close the front door.
9. After the front door is closed, after a short time, the printer control panel displays the
message NEW TRANSFER KIT.
10. If the message NEW TRANSFER KIT does not appear, you must reset the transfer unit
count. To reset the transfer unit count, go to step 11.
11. On the printer control panel, press to highlight YES, and then press to select it. The
transfer unit count is reset, the printer recalibrates, and then the printer is ready to use.
NOTE If the old transfer unit was not at end-of-life when it was replaced (for example, if it was
damaged), the transfer unit count must be reset using the printer control panel.
control panel.
2. Press to highlight Configure Device.
3. Press to select Configure Device.
4. Press to highlight RESETS.
5. Press to select RESETS.
6. Press to highlight RESET SUPPLIES.
7. Press to select RESET SUPPLIES.
8. Press to highlight NEW TRANSFER KIT.
9. Press to select NEW TRANSFER KIT.
10. Press to highlight YES.
11. Press to select YES.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
see pictures on link:
http://www.partshere.com/Models/Q5990A/CLJ_3550%203500%203700Installation_n_config.PDF
Apr 18, 2008 | HP Color LaserJet 3500 Printer
Tektronix Phaser 740P Laser Printer Logo
108 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
Vincent G
Vincent G
STEVE
Vuk B
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
