Hi eddyloz2000,
I believe your drain pump filter is just clogged. The drain pump is
trying to pump the water out before the Spin cycle, but can't. Usually
this is caused by a foreign object that is obstructing the impeller. See
my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it
does not, then you may need to replace the Drain Motor. Which is a easy
task.
Kind Regards :-)
* If this solution helped you, please rate it
Sometimes a little more complex. unscrew the filter and pull it out altogether. Make sure that all the water is out of the tub..Select a spin program then see if the machine does actually spin. If so, then the drain pump has a blockage inside the small impellar housing that needs to be removed.
If no spin take note if there is a capacitor used with the motor. Often, ive had to replace either the 13micro farad or 11 mf cap. That part i suggest you get help with as high voltage needs to be injected in to test for voltage storage.
