you need to check that it supports pal output, if its a european unit
(check the manual and player bottom for the ce mark) then it will play pal discs and will need reverting to the multiregion upgrade ( a disc and a few button presses about £20 online)) if its an american unit then it wont play pal discs even if you do manage to multiregion it.
You can make it regioncode freefollowing these steps..
1. Press "Setup" and go to "PREFERENCES" (DVD stopped and player opened)
2. Scroll to "PBC" using the LEFT/RIGHT arrow key
3. Press "138931" and a pop-up screen will appear.
4. Use the UP/DOWN arrow key to choose the desired number. ( 0 for regionfree!!)
any flashing red powerlight ?? (assuming theres any charge left)
if the powerlight flashes quickly then the units kaput ( bin it)
slow flashing means the microswitch may be stuck (the one that turns off the screen when you close the lid.
you may have to be sneaky at a dealer and ask to plug in to a new mains unit ( most new panasonics still use the same power supply voltage and ampage. if it works then run away quickly and go buy a universal power supply, if it doesnt , well your in the right place tobuy a new one ??
check the microswith near the hinge .
its generally located on near the back right corner of the player , on the control surface. it looks like a very small white plastic button or pip. sometimes these stick down and look like part of the player casing, when they actually are a switch. it needs to be raised , so when the lid is closed it pushes the pip down and turns the screen off. Try prising it gently free with a pin or needle.
this happened tome and i was on the verge of binning it. when i looked at the manual and it says
power light flashing slowly means screen turned off.
if the light is flashing very quickly then im afraid its knackerred and just not worth repairing.
if this is helpful to you then just drop me a line at
[email protected]
good luck
choonzy
Different parts of the world have what is called region codes: North America is 1, Europe is 2 etc...
You cannot play a movie that you have bought from... say the UK on a DVD player you bought from the States.
