SOURCE: SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the
problem continuous the problem can be in the Power supply board, can be defective.
SOURCE: How to set up my Ricoh Aficio 1027 to be a scanner?
NECESITO QUE POR ESPAñOL ME FACILITEN LAS INSTRUCCIONES DE COMO MANEJAR ESTA FOTOCOPIADORA
SOURCE: Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
SOURCE: Installed XP printer driver for Ricoh CL7000 5c
during the installation you have to select this option, by default the duplex option is not selected. Uninstall the software, restart your pc and install the software again, and select the duplexing option. I hope this helps
SOURCE: Ricoh Aficio 2020 All-In-One - printer offline
Under printer check book unmark Use printer offline
