Question about Panasonic Cameras
Hi, i own 2panasonic aj d640 shoulder cams, the one jams the tape each time i try to record, and says in the viewfinder either load ng, t reel ng or rf clog, i really need the camera fixed as i am a second year film student at t.u.t and have many assighnments to complete before november... and any advice on where to buy L cassettes in pretoria,, thanx brenton
6ya staff
SOURCE:
advance
David Millier
  • 107 Answers
SOURCE: Konica Minolta Z5
This sounds like a jammed shutter. There is a very delicate assembly inside your lens which blocks light from the image sensor at the moment you snap the picture in order for it to be able to record what it was seeing at that very moment. Normally after the sensor has finished recording the image the shutter will re-open allowing you to compose another image. If you see the icons and text as you would expect, but do not see any image - this shutter jam is the most likely cause. This assembly is so delicate that even slight impacts, condensation, or contamination from dust or dirt can cause the shutter to not open after it has shut resulting in a black image at all times. The shutter will sometimes clear itself and begin functioning again, but usually it requires disassembly and manual re-setting. Due to the complexity of the lens assembly in this camera (because of the anti-shake features) you will need to send the camera to the manufacturer if you wish to get this problem fixed. David Millier Advance Camera Repair
Posted on Feb 27, 2007
poolseman
zdenek vajdak
  • 206 Answers
SOURCE: recording
This sounds like the CCD sensor is faulty ( this is the device that generates picture in both v-cams and normal digital cameras and sits behind the lens ). Playback is fine but no image ( or very 'noisy' image ) in capture mode. Easy to repair but one has to put a new CCD block in.
Posted on Sep 04, 2007
Anonymous
  • 5 Answers
SOURCE: GoPro Hero Cam FAQ site link is broken, can't load film
Here's our guide to the GoPro hero 5 in PDF format...hope it helps. We also have an unofficial tip sheet. Please contact me if you need a manual for another model camera or for GoPro camera information visit us online at www.IcePlanter.com.
IcePlanter
Posted on Sep 18, 2009
Fabrice Wolters
  • 331 Answers
SOURCE: digital sport head camera e-at18g
I've the same cam, without any problems... Clean the battery contacts in the batterycap and down in the batterycase... Should help!
Posted on Jan 06, 2010
leethedeuce
Lee A.
  • 4472 Answers
SOURCE: My canon vixia hv30 camcorder
First off how long have you owned the camera? It sounds like damage to the recording head has been done. This can only be repaired by a qualified professional. Follow this link to start the repair process through canon. You may also try other independent professionals if you prefer.
https://www.usa.canon.com/consumer/controller?act=OnlineRepairBookingAct
Thank you and good luck,
Lee
Posted on Jul 01, 2010
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
Tape gets stuck
It sounds as though the tape player mechanism isn't working correctly. Either the machine's tape heads are't engaging fully, but usually this is a result of the drive belts becoming worn and not turning one of the tape reel's at the same speed as the other. Culminating in a difference so one reel will run faster than the other, this can cause bunching of the tape as it goes through the tape heads jamming it up. The VCR will need to be inspected by a technician for repair or replacement of the drive belts.
Hope this helps,
James
Apr 25, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
Can a 2 track reel to reel machine play 4 track tapes?
No it doesn't work.
A 2 track recorder is using bandsize /2, and a 4 track bandsize/4.
Regards,
Gerard
Jan 12, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
Play back on Sanyo mr-929 reel-to-reel tape recorder is backwards
I also have an MR-929. The information that you need is in the 'Stereophonic 4 track stereo''. As stereo is only two tracks, there is another 2 tracks in addition to the one you are listening to. Wind the entire reel to the empty spool, and then play that. As you have to physically turn the reel over to do so, you should then hear the other tracks (or track, if recorded in mono).
I use my 929 to play my parents recording of my family from the late 60s, which were recorded on a valve (tube) Ferguson machine, which had a green "magic eye" level indicator, which as a child I found fascinating!
Howie
Mar 31, 2009 | Audio Players & Recorders
What are the best tapes to buy to recrod from your reel to reel. I have some tapes that record and some don;t. Is it becaue they old or defected. Help me out. vp
maxell or tdk (which is hard to find now)....if your reel is 7 inch you want 1800 ft, normal bias (lo noise hi output) tape (for 10 inch you will use the 2400 ft) ....anything longer your tape will be dragging (both while recording and playing) hope this is helpful...feel free to rate
Feb 22, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Worn out part.
you will need to get another unit and cannibalize. These parts are no longer available
Feb 14, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Panasonic aj-d230h
without knowing the exact error message, I can only speculate, but most rewind errors I have seen with the AJ-D230 are related to problems with capacitors on either the reel motor driver board or the system control board. the firewire upgrade (AJ-YAD230) is no longer available.
Sep 19, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Tascam 38
Usually the tension of the take-up reel keeps the shut-off arm taught and everything works. If the shut off arm falls down, the recorder stops. Is that what's happening?
Inadaquate (or NO) take-up tension can cause this; so can WARPED take up reels. Another possibility: if you play a lot of old tapes, the groove in the shut-off arm collects dirt and oxide, so the tape - as it goes through it - jams, and the take-up reel can not overcome the tension. The arm "falls down" and shuts off the machine. Also SOME tapes (which were "cut down" from 2"
tapes) are poorly ****, and will jam some machines.
This is what I do for a living, so if these suggestions don't work, give me more information, and I'll solve your problem.
Jan 01, 2008 | Audio Players & Recorders
Cameras Logo
37 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
